View Poll Results: Select one if you have had a problem with the headgasket the Northstar V8:
Voters
835. You may not vote on this poll
  • 1993
    20 2.40%
  • 1994
    39 4.67%
  • 1995
    13 1.56%
  • 1996
    44 5.27%
  • 1997
    160 19.16%
  • 1998
    180 21.56%
  • 1999
    187 22.40%
  • 2000
    91 10.90%
  • 2001
    65 7.78%
  • 2002
    54 6.47%
  • 2003
    15 1.80%
  • 2004
    8 0.96%
  • 2005
    6 0.72%
  • 2006
    2 0.24%
  • 2007
    1 0.12%
  • 2008
    0 0%
  • 2009
    0 0%
  • 2010
    0 0%
  • 2011
    0 0%
Multiple Choice Poll.
Page 23 of 35 FirstFirst ... 131415161718192021222324252627282930313233 ... LastLast
Results 331 to 345 of 514
Thread: Northstar Headgasket/Cracked Block/Bolt Failure? Please let us know
  1. #331
    fubar569 is offline Cadillac Owners Fanatic
    Automobile(s): 82 fleetwood - 97 deville
    452
    re: Northstar Headgasket/Cracked Block/Bolt Failure? Please let us know
    Bradford, PA
    IIRC drivers bolster and trim on seat is torn/broke and i had some rubbing alcohol spill in the back seat while bowling. this made a nasty spot on the rear seat. missing 2 center caps from stock rims, it's tan interior so it's worn/shows EVERYTHING. 2 minor MINOR (can't see them unless in the sun) "waves" or "dents" in drivers front fender. those are so minor i don't even notice them. it does have a dent in the roof above the windshield drivers side from a baseball. a kid almost died that day. typical carpet wear for 14 years old. drivers side window switch block replaced as well (that little TSB pissed me off). And the dome light panel clip proke so it hangs down from the headliner in the front. It's the dark red/maroon/whatever exterior. a couple small spots starting to form on trunk lid. otherwise in good shape. it was used for driving anywhere and everywhere over 4 years. used to drive an hour each way to work, then to pittsburgh and back, long island and back, etc. didn't care so much about the looks as i did the function.
    will send pics this weekend. in all honesty if someone brought 500 in CASH i'd tell them to load it up and i'd sign the title over. i just want it gone. lol.
  2. #332
    I will talk to him, problem is distance, I have a truck that can tow it, just need to rent a trailer and gas/food $ and I can go.
    Is trans solid?
    Need to find out diff on a 99 SLS engine to a 97 Deville engine...
  3. #333
    452
    trans is very solid. installed April this year. had allegedly around 50k on it when installed but it came used from the Shop's source so no clue. if car is repaired it still has the balance of the 12mo 12k warranty on it. No issues with shifts, fluid consumption, color, etc. In all aspects it's basically perfect.
    i can tell you rockford is basically about 8-10hrs depending on traffic and route taken. tolls are a bastard. about 20-25 each way IIRC. i drove RIGHT THROUGH your area on the 14th of august. too bad i didn't know then....woulda brought a truck and dropped it off for a fee. haha
  4. #334
    VanDamage007's Avatar
    VanDamage007 is offline Cadillac Owners Member
    Automobile(s): 97 Eldorado, Custom body kit, 20" rims, super system........
    15
    Mine happened just after I bought it from the original owner. 68 to 70,000 miles. Cost me nearly $3000.00. No dissapearing coolant but Ive ony got 77,*** on it now. Scared to death of it happening again. Should I still be using the orange coolant or should I change it???
    Thanks!
  5. #335
    stoneface1959 is offline Cadillac Owners Member
    Automobile(s): 2002 seville sts 114000 mi
    Kenmore NY
    57
    15
    Bought 2002 sts at goverment auction they lied, has hg problem i already paid for it, had it shipped from port st lucie florida when it got to me in NY had to put coolant in the car blew white smoke within minutes whats that tell someone
    i got reamed from the gov again.
  6. #336
    452
    for those that expressed interest in my car i can verify it still runs and moves well under it's own power. this will allow you to load it on to a trailer. I will have pics from my droid finally available tomorrow (weather permitting). Needs HG but has newer trans and other parts. 140k miles give or take on chassis. would make good parts car or cheap repair. PM/See Classified for more in depth description.
  7. #337
    wachuku is offline Cadillac Owners Fanatic
    Automobile(s): '97 Seville STS
    Jun 2007
    162
    '97 Seville STS. 150K headgasket failure.
    Bought from Cadi dealer when the car had ~85K and reportedly it had already been timeserted at Cadi dealer.
  8. #338
    Pete1996 is offline Cadillac Owners Fanatic
    Automobile(s): 2006 DTS, 1996 STS - RIP
    CT - USA
    197
    Re: Definitive Northstar Headgasket Thread
    1996 STS Began coolant consumption at about 120K miles, HG failure at 162K miles
  9. #339
    97 Seville SLS is offline Cadillac Owners Member
    Automobile(s): 1997 Seville SLS
    97 Seville SLS -- headgasket failure at 94k. Not sure what to do with it. Have a Cadillac mechanic that will fix it for $2,500 - $3,000, but the car obviously isn't worth much more than the repair bill with the bad resale value they have. Is there any market for these things that need headgasket repair? About ready to scrap it and move on.
  10. #340
    Friend of mine has a rear ended 99 SLS that has a fresh low miles N* that was swapped in. It is up for sale, if anyone is interested, let me know. Get whole car for fraction of cost of repair...
  11. #341
    83CADMAN's Avatar
    83CADMAN is offline Cadillac Owners Fanatic
    Automobile(s): 83 Eldorado, 90 Seville, 94 Concours
    Pacific Northwest
    62
    467
    Quote Originally Posted by 97 Seville SLS View Post
    What does the $2500 buy? Jakes Stud kit?
    If its done right couldn't the car see 300k miles? Whatís that worth?
    Seems to me the value would be a no brainer. A dollar saved is a dollar earned and itís tax-free.
    Iíve got a 94 Concorse with the 300hp N*. Iíve been sitting on it for two years now. I plan to to Jake stud it, but other things seem to get in the way.
    Its also a low miler one owner car and is mint through out. Absoulty beautful automobile. The leak is small and is in the forward head. Its starts and runs enough to baby around the neighborhood, to the store and stuff, so its not my daly driver.
    I figure, a lot of these cars are being crushed at this very moment and when there all goneÖever heard of the Edsel?
  12. #342
    foxjohnc is offline Cadillac Owners Member
    Automobile(s): '97 DeVille present, '99 DeVille past
    Huntsville, AL
    Where are you located and how much do you want for the car. Im looking for a northstar powered car to fix for the wife to drive.
  13. #343
    Jesda's Avatar
    Jesda is offline Super Moderator
    Automobile(s): 2002 Seville STS F55, 2006 Mazda Miata
    DETROIT
    22,381
    2001 120k. Very slowly loses coolant. Failed block test. Not yet overheating.
  14. #344
    Quote Originally Posted by 83CADMAN View Post
    Mechanic quoted $2,500 - $3,000 and that includes: stud kit, all labor, and he will replace anything under the hood I want for the cost of the parts while the engine is out -- no additional labor. I have 4 cars including the Seville, so I don't have to rush into fixing it. Probably worth it to fix, but I don't have the money right now.
  15. #345
    Quote Originally Posted by foxjohnc View Post
    foxjohnc
    I am located in Cincinnati, OH. Here is some info on the car:
    1997 Seville SLS
    94,xxx miles
    Red with Tan Interior
    I lose some coolant through the exhaust, but the head gasket isn't that bad yet
    Is exhaust present in the coolant tank -- no coolant in the oil
    Still runs great except for idling rough in cold weather
    Driver's window motor is bad -- needs replaced
    Otherwise very clean and still a very nice ride
    Not sure what it's worth, but feel free to make me an offer:
    stag302 at yahoo dot com
    513 201 7151
