Flickering
Results 1 to 4 of 4
Sharp HID Discussion, Flickering in Authorized Cadillac Vendors; Had this kit in for like 4 days and now one of the lights are flickering. Didn't have time to ...
    Fast is offline Cadillac Owners Member
    Automobile(s): 02 Deville DTS
    Jan 2011
    34
    72
    Flickering
    Had this kit in for like 4 days and now one of the lights are flickering. Didn't have time to swap th ballast yet
    Quick reply to this message Reply
    SharpHID is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Mar 2008
    130
    Re: Flickering
    Is this in the low beams or fogs? Swapping the components will help diagnose. I would also check the connections.
    Keep me posted.
    Regards,
    John
    Jan 2011
    34
    72
    Re: Flickering
    I disconnected and reconnected the plug that goes into the ballast and everything is back to normal. It was only the drivers side that was doing it, I haven't installed the fogs yet. Ill keep updated if problem persists.
    Mar 2008
    130
    Re: Flickering
    Hello,
    That sounds good. It sounds like just a loose connection then which we see from time to time.
    Thank you for the update.
    Regards,
    John
  7. Remove Advertisements
  • You may not post replies
