Does your rear air suspension in your 1993-1996 Fleetwood deflate when you turn it off?
Does you air compressor kick in every 30 minutes?
Does your the rear of your Fleetwood sit high?
Well I have the solution for you!!
I got rid of my air shocks and compressor a long time ago.. but fast forward to yesterday: I took out the Impala SS springs I have in the rear. The SS springs are not heavy duty enough for the rear of the Fleetwood. If I carried any rear passengers, or put anything with some weight in the trunk, I would bottom out or rub the Borla exhaust tips.
So.. I bought a set of new heavy duty 9C1 Caprice springs and put them in the back. Matched with the Bilsteins, UMI control arms, & Hotchkis bars.. the car is perfect now. It is a good height in the rear and they are much smoother than the SS springs.
So my combination of SS springs/Bilsteins in the front paired with 9C1 springs/Bilsteins in the rear worked out great.
FYI, these springs are found at AutoZone under Impala SS Heavy duty springs.
Take care,
Elias
Take care,
Elias
