fleetwood carb rebuild
Results 1 to 6 of 6
1985-1996 Fleetwood and Brougham Forum Discussion, fleetwood carb rebuild in Past Cadillac Vehicle Discussion; Hey all. On my 86 Fleetwood Brougham with an olds 307 - I'm rebuilding the carb because it was filthly ...
    hankk17 is offline Cadillac Owners Fanatic
    Automobile(s): 78 Eldorado x2; 99 Eldorado
    Feb 2004
    Boston area
    50
    124
    Hey all.
    On my 86 Fleetwood Brougham with an olds 307 - I'm rebuilding the carb because it was filthly and seriously carbon fouled.
    Any tips or things to watch out for?
    Any reason that the choke is not adjustable and the needle valves have been capped off?
    I'm not going to touch either of them aside from cleaning and re-assembling.. but was curious as to why they were setup this way.
    Thanks!
    -Hankk17
    FASSTWOOD's Avatar
    FASSTWOOD is offline Cadillac Owners Enthusiast
    Automobile(s): 1995 Fleetwood Brougham
    Aug 2003
    Queens, NY
    44
    709
    Re: fleetwood carb rebuild
    They do sell a kit which is like a little hole saw to access those set screws I think hygrade made it
    Feb 2004
    Boston area
    50
    124
    Quote Originally Posted by FASSTWOOD
    I can easily get to the screws.. it'd just be a matter of using a chisel and cutting out the bits of metal holding the plugs in place over the adjustment screws.
    The question is - should I, or should I just leave it alone? At this point I have only cleaned and re-assembled the carb. It hasn't gone back on the engine yet.
    FASSTWOOD's Avatar
    Aug 2003
    Queens, NY
    44
    709
    I would chisel them out just to have access to them just in case. It wouldn't hurt....
    Imprl59 is offline Cadillac Owners Fanatic
    Jan 2004
    300
    These were covered to stop people from futzing with them causing the engine to go out of spec on emissions. I would go ahead and remove them now just in case you ever need to make an adjustment.
    Steve B.
    Feb 2004
    Boston area
    50
    124
    actually, I took the safe way out and just left the caps on. I put it all back togther today and it runs 100X better - no need to futz with the needle valves, so I didn't even bother.
    Thanks for the replies guys!
  9. Remove Advertisements
