Heater Resistor
Results 1 to 11 of 11
1985-1996 Fleetwood and Brougham Forum Discussion, Heater Resistor in Past Cadillac Vehicle Discussion; Hey does anyone know where to find the Blower motor resister for my 1987 cadillac brougham (307 v8) ?? If ...
    CaddylacBrougham's Avatar
    CaddylacBrougham is offline Cadillac Owners Member
    Jan 2004
    NY
    61
    Heater Resistor
    Hey does anyone know where to find the Blower motor resister for my 1987 cadillac brougham (307 v8) ?? If you could help I would be very thankful because its becoming annoying without heat in the cold I can't find it in the manual for my car
    Spock's Avatar
    Spock is offline Cadillac Owners Fanatic
    Dec 2003
    Alberta, Canada
    437
    Re: Heater Resistor
    I believe it is on the passenger side in the car, just above where their feet would be.
    Take off that plastic shield and it should be there.
    Right now I'm trying to get my heater going as well still, I was first under the impression that it's outside of the car and now I believe it to be on the inside. Have done quite a bit of reading in the past forums here but still can't find it...
    I simply don't know what it looks like lol. I check all the wire leads and *assume* its some parts.
    jmblimo's Avatar
    jmblimo is offline Cadillac Owners Member
    Nov 2003
    NC / SC
    18
    Re: Heater Resistor
    It's out under the hood. Located on top of the A/C box, it has a large black ground wire going to it, as well as, an 6-wire electrical connector from the harness. Also, it is called a "power module." These go bad a lot. Maybe someone has a picture they'll post.
    FASSTWOOD's Avatar
    FASSTWOOD is offline Cadillac Owners Enthusiast
    Automobile(s): 1995 Fleetwood Brougham
    Aug 2003
    Queens, NY
    44
    709
    Re: Heater Resistor
    Here you go...
    Jan 2004
    NY
    61
    Re: Heater Resistor
    Hey thank you very much for the pic and the info I will soon be on my way to heat
    Jan 2004
    NY
    61
    Re: Heater Resistor
    Hmmm does anyone know what to test on it to see if it works? like what prongs to test with the ohm meter etc.?
    FASSTWOOD's Avatar
    Aug 2003
    Queens, NY
    44
    709
    Re: Heater Resistor
    Quote Originally Posted by CaddylacBrougham
    Its held in by two screws, just pull them out and look at the coils. You will be able to tell if the coils are broken.
    Jan 2004
    NY
    61
    Re: Heater Resistor
    Ok I took it out and the coils don't look broken. If that is a common part to break then they are pretty expesive the local advanced auto wants 167.77 for that stupid thing. What else could be making the blower motor stay on when the car is off?
    FASSTWOOD's Avatar
    Aug 2003
    Queens, NY
    44
    709
    Re: Heater Resistor
    I had a similar problem also. but once i opened the hood it would turn off. It turned out to be the wrong blower i the car and the flange of the blower would ground itself against the hood spring in the hinge when i closed the hood. the positve is constant in my car and the ground regulates the speed.
    hope this helps...
    Jan 2004
    NY
    61
    Re: Heater Resistor
    What do you mean by wrong blower? hmmmm thinks cause the power module looks good to be in good condition.
    FASSTWOOD's Avatar
    Aug 2003
    Queens, NY
    44
    709
    Re: Heater Resistor
    The guy that owned the car before me swapped out the original blowerfor one that he probably had laying around or picked up froma junk yard. The flange that bolts to the heater box had a different shape to it and was grounding out against the hood spring.
  14. Remove Advertisements
