Car Craft RSE Preview link ( Cad Wins!) - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 24 of 24
1985-1996 Fleetwood and Brougham Forum Discussion, Car Craft RSE Preview link ( Cad Wins!) in Past Cadillac Vehicle Discussion; HP isn't the issue when modding a FWD car for drag racing. The big issue is getting it to hook-up ...
  1. #16
    Katshot's Avatar
    Katshot is offline Cadillac Owners Master
    Jan 2003
    Newtown, PA
    58
    6,472
    HP isn't the issue when modding a FWD car for drag racing. The big issue is getting it to hook-up so you can get a good ET. Body, suspension, and tires are all major draw-backs to FWD cars that must be overcome. This why the major sanctioning bodies have adopted a seperate class for FWD drag cars. It was determined that RWD cars had an advantage. DAH!!
    Kevin
  2. #17
    DeVillish's Avatar
    DeVillish is offline Cadillac Owners Connoisseur
    Jan 2003
    Okinawa japan
    32
    1,623
    Well right now iam worried more about my handleing more than going fast in a stright line, while that is fun, going fast while turning is more fun in opinion. Any ideas about that?
  3. #18
    jeff schwartz is offline Cadillac Owners Member
    Jan 2003
    30
    Put low profile 17-18" tires and wheels, contact sway bar companies for some large dia units, install KYB or TOkico struts/shocks. and attack the corners.
  5. #19
    DeVillish's Avatar
    Jan 2003
    Okinawa japan
    32
    1,623
    I was looking at the ajustable KYB shocks, but they say only the GR2s will fit my car. Also i have the shelf leveling rear suspension, whats that do anyway?
  6. #20
    Jan 2003
    30
    I have KYB non adj on my 82 Ftwd. I also used to have level ride. It was basically air shocks connected to a compressor. If you do away with the level ride. You'll probably have to cut one coil from the front springs to get the stance right. Which is what I did. Most sway bar companies, If they don't have bars for your car, could make some. I saw an ad in Grassroots Motorsports the other day for a company that will make any custom bar for about $100 ea.
  7. #21
    Mad'lac's Avatar
    Mad'lac is offline Cadillac Owners Connoisseur
    Automobile(s): 1984 Fleetwood Brougham coupe
    Dec 2002
    Floresville, Texas
    42
    1,576
    Hey Jeff, if I added Impala SS springs do I need to get rid of the level ride?Are the air shocks the only shocks on my car? I was planning to add Tokico shocks when I install the springs.
  8. #22
    Jan 2003
    30
    yea, the air shocks are the only rear shocks on the car. If you remove and replace with normal shocks, the car may sit a little low in the rear. As stated above, I cut one coil from the front.
  9. #23
    HotRodSaint's Avatar
    HotRodSaint is offline Cadillac Owners Master
    Automobile(s): 1996 Fleetwood Brougham
    Jan 2003
    SoCal
    53
    7,237
    I like your front bumper mod. Did you do the glass yourself?
  10. #24
    Jan 2003
    30
    Both bumpers are made from .060 Aluminum Sheet stock.
    10 lbs each. I did them myself.
  11. Remove Advertisements
