RWD 19xx-1984 DeVille and Fleetwood, 1985-1996 Fleetwood and Brougham ForumForum for discussions regarding the rear wheel drive Pre80s-1984 DeVille and Fleetwood, 1985-1996 Fleetwood/Brougham.
I need to find a new or used "fast idle valve" for my 1976 Fleetwood Brougham 500cid EFI engine. The original part has the following written on it: BENDIX 1181835 however I am unable to find this part coz it is probably discontinued. At online partssuplliers the subtitution part is a STANDARD ES33 SOLENOID, however that part is totally different than the original, it doesn't fit into the throttle body, it is a mistake.
Can anybody help me where to look?
Here are 2 pictures from the shop manual.
Does the valve work, or is it broken? The fast idle valve on my '76 EFI Fleetwood idled too high, and I used some shims to bring the RPM's down. It worked since that's a very hard part to find! Heck, ALL the EFI parts for those cars are scarce!
Thanks guys, I know it is a little late now (I had no access to the forum for a long-long time) but everything is solved now. I bought already 3 valves (better than none ) on Ebay, everything is fine now!
