Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > RWD 19xx-1984 DeVille and Fleetwood,
1985-1996 Fleetwood and Brougham Forum
Forum for discussions regarding the rear wheel drive Pre80s-1984 DeVille
and Fleetwood, 1985-1996 Fleetwood/Brougham.
Cadillac Forums: How do ya check diagnostics on '95 FWB?
Old 01-26-04, 12:57 PM
View jc95fwd's Photo Album
Casino Cash: $250
Question How do ya check diagnostics on '95 FWB?
Lately, I am getting a "Check Engine" light occasionally and don't have a clue why; everything seems to be running fine. How do you check the engine diagnostic codes on a '95 Fleetwood Brougham? I turned the ignition to "on", pressed "off" and the warmer arrow in for at least three seconds but that didn't seem to work???
  #2 (permalink)
Old 01-26-04, 02:28 PM
DaveSmed's Avatar
Got Torque?
Cadillac(s): 1968 Cadillac Sedan deVille, 1994 Chevrolet G20
View DaveSmed's Photo Album
Casino Cash: $1700
Re: How do ya check diagnostics on '95 FWB?
I know that you have to scroll through different systems, that it's not automatic. I'll move this into the Fleetwood section, so someone can give you a better answer.
  #3 (permalink)
Old 01-26-04, 06:04 PM
Casino Cash: $250
Oops; I later found out about scrolling through the systems... Does anyone know what a code of 126 in the HVAC system (02) means?
  #4 (permalink)
Old 01-26-04, 08:10 PM
FASSTWOOD's Avatar
Cadillac Owners Enthusiast
Cadillac(s): 1995 Fleetwood Brougham
View FASSTWOOD's Photo Album
Casino Cash: $275
26 is the dtc code the 1 in front of it means that it was a stored code
in the book it says
serial data communication (circuit shorted to B+,shorted to ground, or open circuit)
this is a post from the impalssforum hope it helps!
Come on guys... Let the car tell you what the problem is. Remember you are driving a Fleetwood!!!
With the car running, hold the "OFF" and "Temp Up" buttons down at the same time for about 5 seconds. This will bring up a segment check and then take you into computer "00" (PCM) diagnostics.
Now press the "Out Temp" button and record any codes. If you see a code prefixed by a "1", this is a history code.
Use the "Warmer" button to move on to computer "01" (CCM) and repeat the procedure.
Continue through the last 3 computer systems... 02=HVAC, 03=SIR, 04=ABS/TC
If you don't have "the book", let me know what codes show up and I'll give you the run down.
Oh yeah, if a code is being displayed, you can select the "OFF" button to instantly clear that code from the system. This will get rid of any intermittent problem and get those lights off of the dashboard. If the problem is real, the code will be set again and the lights will come back on.
  #5 (permalink)
Old 01-26-04, 08:48 PM
View VIN Guy's Photo Album
Casino Cash: $250
On that particular code, if it is a current code (active, meaning the PCM is not getting a signal from HVAC controls), then your AC compressor will run all the time. If it just lost connection in the past, and the connection is currently working, I'd clear the code and see if it returns. If so, you've got a short, or a bad HVAC control most likely.
  #6 (permalink)
Old 01-27-04, 09:46 AM
Casino Cash: $250
Question Re: How do ya check diagnostics on '95 FWB?
Thanks alot for the info. I cleared that code and will see if it ever returns. Now this morning I had the check engine light come on for a while again, but when I went to check the diagnostics what I got was: in the 05 category (is there such a section) there was initially a 161, then a 163. Any idea what the heck that means?!
  #7 (permalink)
Old 01-27-04, 11:30 PM
FASSTWOOD's Avatar
Casino Cash: $275
that might of been engine temp. I gotta check but i left my manuals at work
get back to ya.
  #8 (permalink)
Old 01-28-04, 09:32 AM
Casino Cash: $250
get back to ya.
That makes sense; thanks. Off the topic, but do you know what the diameter size is for the muffler inlet/outlets and if they are both offset or on is in the center? I'm gonna order the Summit Turbo mufflers and could of course just go out and lay on the ground and look/measure, but here in Cincy right now it's 10 degrees with about 6" of snow on the damn ground!
  #9 (permalink)
Old 01-28-04, 09:41 PM
FASSTWOOD's Avatar
Casino Cash: $275
Check here...dyomax I thinks its 2 1/2 offset offset
Tags: , ,
check, diagnostics, fwb
