Hi, Finishing a restoration for someone who owns a 56 Fleetwood. I am installing the transmission shift indicator that screws into the column. The problem is, the indicator doesn't line up properly with the letters for the shift postion. I have the clip on the column and when I install the pointer and go through the gears it gets fouled up and pops off. I have tried installing it every which way but cannot get it correct. Any help is appreciated. The pointer looks like this
I want to try to avoid that as the trans goes into all gears as of right now and I don't really want to mess with it. It looks like the manual linkage is set up "correct" as the cutout for the clip makes a full run in the steering column cutout. Well, as long as it is supposed to do that.
I have the same issue on my 69 calais after i dropped the steering column to replace the ignition switch. Never could get it set up right again so I just shifted it by number of clicks. I know that doesn't help for your customer, sorry.
If anyone does have info on adjusting these I'd also be interested.
Related Threads
Cadillac Owners Forum
4.8M posts
369.7K members
Since 2002
