power antenna from 1991 fit my 1979?
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 21
Like Tree5Likes
1985-1996 Fleetwood and Brougham Forum Discussion, power antenna from 1991 fit my 1979? in Past Cadillac Vehicle Discussion; A friend offered me a power antenna from a 91 Brougham which he thought may fit my 79 deVille. This ...
    Bro-Ham's Avatar
    Bro-Ham is offline Cadillac Owners Connoisseur
    Automobile(s): 1979 Sedan deVille d'Elegance
    Oct 2005
    Sarasota, FL
    49
    4,152
    A friend offered me a power antenna from a 91 Brougham which he thought may fit my 79 deVille. This doesn't sound right to me but I wanted to know for sure.
    About 10 years ago I replaced the original antenna on my 79 with an aftermarket power antenna assembly which still works but needs to be replaced because the plug came off the cable and now I no longer get AM. Of course I can't locate the car's original antenna that I thought was saved somewhere.
    If this 91 antenna is not workable then I will attempt to find a used antenna from a 1979, will 77-78 work as well? Those two years had the dash switch which my 1979 does not.
    deVille33 is offline Cadillac Owners Connoisseur
    Automobile(s): 1977 Coupe (blue), 1977 Coupe (yellow), 1977 Coupe (green)
    Mar 2006
    Western Massachusetts
    1,493
    Re: power antenna from 1991 fit my 1979?
    The '81 looks similar and there wasn't a lot of design change that it wouldn't work. I don't have pics on this computer. Try and mock it up.
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,896
    I used a later 80s/early 90s on on my 81. All I had to do was alter the mounting a little on the later antenna. Dig in my "Cadillac" section of my photobucket. My internet is too slow right now to get the links.
    Bro-Ham's Avatar
    Oct 2005
    Sarasota, FL
    49
    4,152
    Doesn't the 1991 have a power antenna on the rear fender? This doesn't seem compatible with a 1979 with a power antenna on the front fender.
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,395
    Quote Originally Posted by Bro-Ham View Post
    Nope. B bodies didn't have antennas on the quarters.
    Sep 2006
    Ontario, Canada
    44
    7,896
    Well... the Cadilac is a C/D body... and the 93-96 do have the antenna on the right rear 1/4 panel...
    Dec 2010
    St. Louis, MO
    6,395
    Quote Originally Posted by jayoldschool View Post
    Doh... Forgot about those stupid trunk mount radios.
    silverfox103's Avatar
    silverfox103 is offline Cadillac Owners Fanatic
    Automobile(s): 96 Fleetwood & 07 CTS, 94 Roadmaster Wgn & 94 Caprice Wgn
    Aug 2012
    Littleton, NH & St. Simons, GA
    67
    399
    Roadmaster sedans also have the antenna mounted on the rear fender.
    Tom
    bigm57ict's Avatar
    bigm57ict is offline Cadillac Owners Connoisseur
    Automobile(s): 1979 Coupe deVille, 1995 Sedan DeVille (sold)
    Aug 2011
    Wichita Kansas
    44
    1,845
    You are thinking of the '93-'96 Fleetwoods. '90-'92 Broughams have the fender mounted antennas, just like '77-'89
    the APEMAN is offline Cadillac Owners Enthusiast
    Automobile(s): 1980 FBC
    Mar 2010
    54
    537
    How about repairing the connector?
    Bro-Ham's Avatar
    Oct 2005
    Sarasota, FL
    49
    4,152
    Quote Originally Posted by the APEMAN View Post
    Is that possible? Connector pulled off the cable completely.
    Sep 2006
    Ontario, Canada
    44
    7,896
    Yes, you can get the connector from a place like Monoprice, and the crimping tool at Home Depot (or Monoprice). It's coax, same as cable TV.
    Mar 2010
    54
    537
    I've repaired connectors. If what you have is a cable that used to plug into the radio with a ripped off connector there's hope.
    Most car coaxial cable uses a tiny inner conductor to give it a high impedance. The cable is not matched as most coax is. This makes it a little tricky but not impossible.
    Glad someone still cares about AM : )
  16. #14
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,431
    If it's the the end connector with the pin like the kind that pushes straight into the back of the radio you can get replacements for those at Radio shack. They come with little set screws that hold it all together so you don't need any special tools.
    the APEMAN likes this.
  17. #15
    Bro-Ham's Avatar
    Oct 2005
    Sarasota, FL
    49
    4,152
    Thanks everyone! I will give it a try with these suggestions and hope my existing setup can be made to work again. FM is currently fuzzy and AM does not come in at all which is frustrating since, yes Ape, I love AM talk radio, particularly Rush, and lately listening through my device on iHeart and my Bluetooth headset is a PITA.
    I will report back on what happens after I get the parts and pieces and attempt the repair - maybe I will have the mechanic tackle it too, we'll see. I appreciate the advice and counsel as always!
  18. Remove Advertisements
