HOT "NEGATIVE" battery terminal two times
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 21
Like Tree5Likes
1985-1996 Fleetwood and Brougham Forum Discussion, HOT "NEGATIVE" battery terminal two times in Past Cadillac Vehicle Discussion; little problem, guys... First time it happened week ago: 1-insert ignition key, turn ON-all necessary bulbs is ON, AirBag is ...
    alexgrig's Avatar
    alexgrig is offline Cadillac Owners Member
    Automobile(s): 94' Fleetwood Brougham
    Jan 2011
    Ukraine, Kiev
    42
    98
    1-insert ignition key, turn ON-all necessary bulbs is ON, AirBag is 7 times, so OK.
    2-Key to START and i see AIRBAG lamp is ON continuos, NOT FLASH 6 times.
    3-i stopped and i hear strange sound from right side underhood, sounded like "zzzzzzzz" sound
    CANNOT to start again-turn of key brings to nothing-NO CRANKING.
    4-Negative terminal TOO HOT.
    After disconnect -terminal and waiting for 5 minutes and reconnecting-ALL is OK-AirBag 6 times flashing.
    I was cleaning up negative terminal and driving one week with NO problems, but today it's situation come back again.
    WTF?
    starter is dying?
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,612
    Re: HOT "NEGATIVE" battery terminal two times
    Does the airbag blink normally or is that new? Follow your battery wires to make sure they haven't melted and are touching metal or something. I'm not sure what it could be.
    alexgrig's Avatar
    Jan 2011
    Ukraine, Kiev
    42
    98
    AirBag blinks NORMALLY-7 times when key is ON and 6 times when START.
    Only TWO times AirBag do not blinked, when HOT terminal is happened.
    Of course, all wires was carefully checked-NO melted, NO damage etc.
    POSITIVE terminal is OK.
    NO parasitic load.All electrician equipment is OK.
    Some ukrainian guys talk about starter "locked" inside-randomly locked and unlocked.
    btw, 85-100F outside-very hot and dry.
    more btw - recently i had some of leaking oil from seals, but in spring this year all leakage resolved, so starter now NOT in much oil as previous.
    Is it possible of "not enough" lubrication inside starter?
    Engine now is absolutly dry
    Some details about cranking-when hot time, my cranking time near 4-5 sec, but in cold cranking LESS then 1 second.
    Car is 21 years old, mileage 74 kmiles, previous hosting during first 18 years was not so much good.
    outsider is offline Cadillac Owners Connoisseur
    Automobile(s): 87 Brougham, 1969 Calais, 95 FWB, 05 CTS, 07 SRX
    Sep 2009
    Buxton, Maine, United
    33
    4,149
    I'm not sure but you can take your starter off and have it tested at most parts stores (at least here in the US...) You might want to try that. You can also have them test your battery. I don't know if a bad battery would necessarily cause this issue but i wouldn't rule it out since most places will test your battery for free.
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,431
    airbag light flashing shouldn't have anything to do with starting. If the cable was loose or not making good contact that can make them get hot. If it's not getting hot now and is starting don't worry about it.
    If you turn the key and the starter won't turn but it's draining power there's a chance it could be bad starter or possibly another loose/dirty connection.
    alexgrig's Avatar
    Jan 2011
    Ukraine, Kiev
    42
    98
    btw, NO ERROR CODES according to Climat Diagnostic.
    All positions -00- -04 totally shown ZERO's.
    Battery is OK- green light in battery indicator, all measurements is OK too.
    hmmm....
    When i saw AirBag NOT flash and lights ON, i STOPPED and turn ignition OFF. Strart again was IMPOSSIBLE until i disconnect hot NEG cable from battery and wait near 5 minutes.
    After reconnecting start was successful
    Sep 2009
    33
    4,149
    It could possibly be a bad battery wire, too. Maybe it's making too much resistance (resistance = heat) and preventing the current from flowing properly?
    csbuckn likes this.
    Jan 2008
    Minneapolis
    5,612
    I think Outsider is on the right track. That negative cable is probably bad or has a bad connection. Resistance creates heat.
    alexgrig's Avatar
    Jan 2011
    Ukraine, Kiev
    42
    98
    New original NEG cable is on the way, during next week i will replace cable, but strange "ZZZZZ" sound very suspicious for starter "sticking"....
    Sep 2009
    33
    4,149
    you can get the same sound if there's not enough juice going to the starter. If the cable is bad and not letting enough juice through that could be causing the zzzz sound too.
    deVille33 is offline Cadillac Owners Connoisseur
    Automobile(s): 1977 Coupe (blue), 1977 Coupe (yellow), 1977 Coupe (green)
    Mar 2006
    Western Massachusetts
    1,493
    If it is not the cable, it could be the ground connection. Look for corrosion and clean up the frame where the ground connection attaches. Earlier Cadillac engineers went to Aluminum ground cables. They would corrode inside the sheathes. The cables would swell where the cable corroded. As someone stated corrosion creates resistance to current flow. The noise is actually the current amperage reacting to the resistance. Vibration.
    alexgrig's Avatar
    Jan 2011
    Ukraine, Kiev
    42
    98
    Replaced starter with new unoriginal from Cargo, parts# 112897.
    "zzzz" sound came from starter, it's clear after some of testing procedures.
    According to mechanics, some parts inside starter was stick on the drive shaft...
    thanks for all
    Cadillacboy and csbuckn like this.
    Cadillacboy's Avatar
    Cadillacboy is offline Cadillac Owners Connoisseur
    Automobile(s): 1996 Cadillac Fleetwood Brougham
    Dec 2003
    36
    4,388
    Happy days , it's nice to see you got it fixed
  16. #14
    alexgrig's Avatar
    Jan 2011
    Ukraine, Kiev
    42
    98
    not finally fixed
    next step-to buy original 10465143 ACDelco starter.
    it must be two week for shipping
    No one part in my Caddy will be unoriginal
    btw, what difference between 10465143 and 19135434 starters?
    price almost twice more of 10465143
  17. #15
    thefleetwoodguy is offline Cadillac Owners Enthusiast
    Automobile(s): 95 triple black fwb
    Dec 2008
    S NH
    56
    890
    Alex , your car is more gm/ac/delco then any one of ours !! I give you credit bro you do it right
    hope things start settling down over there soon , stay safe my friend!!!
    alexgrig likes this.
  18. Remove Advertisements
