Remove cluster bulbs! How?
Results 1 to 14 of 14
Like Tree4Likes
  • 2 Post By jayoldschool
  • 1 Post By Mattia-SS
1985-1996 Fleetwood and Brougham Forum Discussion, Remove cluster bulbs! How? in Past Cadillac Vehicle Discussion; I got the cluster lens off but I have no idea how to remove these small bulbs! Any ideas? Car ...
    Mattia-SS's Avatar
    Mattia-SS is offline Cadillac Owners Member
    Automobile(s): 1996 Fleetwood Brougham
    Jan 2014
    Sweden
    45
    59
    Car is a 1996 Fleetwood Brougham
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,879
    Re: Remove cluster bulbs! How?
    Bulbs come out from the back. Grab the black base, twist counter clockwise.
    Mattia-SS's Avatar
    Jan 2014
    Sweden
    45
    59
    Whatīs a black base? Sorry, english isnīt my primary language
  5. #4
    Sep 2006
    Ontario, Canada
    44
    7,879
    Black as in colour.
    This isn't a Cadillac, but it will make sense...
  6. #5
    Mattia-SS's Avatar
    Jan 2014
    Sweden
    45
    59
    Thanks! I will try it tomorrow..
  7. #6
    Mattia-SS's Avatar
    Jan 2014
    Sweden
    45
    59
    I donīt understand!! Where do I go from here? The cluster seems loose but I donīt want to use force and pull it. What did I miss??
  8. #7
    talismandave's Avatar
    talismandave is offline Cadillac Owners Master
    Automobile(s): 1980 Eldorado, 1974 Talisman, 2004 Volvo C70,
    Mar 2012
    Madison WI
    57
    7,886
    You are looking at the front side of what Jay posted the backside of.
    I can not advise further, I have never worked on your model car, and I don't think the older cars come apart like that without removal from the dash first.
    Sorry.
  9. #8
    Mattia-SS's Avatar
    Jan 2014
    Sweden
    45
    59
    I just found a contact on the backside barely visible with a flashligt. Is that the one I have to pull before I can get the cluster out? If i succeed doing that I donīt Think I ever will be able to put it back!
  10. #9
    Sep 2006
    Ontario, Canada
    44
    7,879
    If you've taken out the cluster mounting screws, you simply pull the cluster towards you. Friction is the only thing holding it in the connection for the wiring. You also need to take the gear indicator connection off the column. You can put back the front of the cluster, you don't get the bulbs out that way.
    Ok, back from the garage. I knew I saved this thing for something.
    Here we go. Front of the cluster. There are four mounting screws to remove. On the white part.
    Slide the gear selector clip off the column.
    Pull the cluster towards you. The only thing holding it is those two electrical connectors.
    Bulbs (green/brown, not black, sorry) simply turn counter clockwise and pop out.
    If you can't turn them by hand, use a pair of pliers to grip and turn gently.
    There you go. How to remove your bulbs.
    Anyone need that cluster? lol
    pompste and talismandave like this.
  11. #10
    Mattia-SS's Avatar
    Jan 2014
    Sweden
    45
    59
    Thanks for the explanation with pics and all :-) So it was never ment to pull the connectors out from the backside? Once I put the cluster back it will slide in to the connectors again?
  12. #11
    Sep 2006
    Ontario, Canada
    44
    7,879
    Yes, you press it in place, it will be snug. The connector ends are mounted securely in the inner dash.
    You're welcome, glad to help. Pictures can cross any language barrier.
  13. #12
    Mattia-SS's Avatar
    Jan 2014
    Sweden
    45
    59
    Quote Originally Posted by jayoldschool View Post
    Thanks a lot, thatīs exactly what I wanted to know. I will give it a go on sunday.
    talismandave likes this.
  14. #13
    Mattia-SS's Avatar
    Jan 2014
    Sweden
    45
    59
    Done! If I only would have known it was that easy
  15. #14
    tyler little's Avatar
    tyler little is offline Cadillac Owners Fanatic
    Automobile(s): 1995 cadillac fleetwood brougham
    Jun 2014
    Brantford Ontario Canada
    21
    199
    What type/size screw driver is needed to remove the black bulb covers?
  16. Remove Advertisements
