HT4100 power steering pulley
Results 1 to 5 of 5
1985-1996 Fleetwood and Brougham Forum Discussion, HT4100 power steering pulley in Past Cadillac Vehicle Discussion; I'm trying to remove the water pump on my '83 cadillac but have struck a problem with the power steering ...
    cindy-sue is offline Cadillac Owners Member
    Automobile(s): 1983 Cadillac Coupe DeVille
    Aug 2014
    6
    I'm trying to remove the water pump on my '83 cadillac but have struck a problem with the power steering pulley. It has a hex pattern thread but I'm sure there's a
    snapped bolt in there from a previous repair. When I can get that out, I'll need to
    know how to get the pulley off. I've done lots of reading on this forum and
    understand the pulley puller threads into this hex pattern. Could somebody please
    tell me if this is correct and could somebody please post a picture or link to the
    pulley puller I need. Thanks
    grauhst's Avatar
    grauhst is offline Cadillac Owners Fanatic
    Automobile(s): 83 FWB d'Elegance, 83 CDV, 83 FWB, 74 Lincoln Mark IV
    May 2013
    Stralsund, Germany
    27
    371
    Re: HT4100 power steering pulley
    When I removed it:
    With this tool: (sry, it is a german link. There definately is something like that in the US too)
    http://www.ebay.de/itm/Lichtmaschine...item19eb149b90
    Regards
    Felix
    j2rossit is offline Cadillac Owners Enthusiast
    Automobile(s): 85 FW Brougham, 68 Wildcat 'vert, 92 & 96 Roadmaster Wagons
    Jan 2011
    Southern Ontario
    934
    I was able to loan the tool from my local part store. But the pull was on so tight that the flange of the pulley broke off before the pulley came off. So out came the angle grinder and I had to replace both the pulley and the pump.
    caddy1983 is offline Cadillac Owners Fanatic
    Automobile(s): 1983 Fleetwood brougham 2 door
    Oct 2009
    110
    Hey Cindy-sue this is exactly what I need to do to my 83 2 door d'elegance. so far has it been difficult for you. what name brand of water pump are you getting? also what I have been reading is that the water pump has two ring type of seals that go in a tube like opening. This will need to be
    installed properly or else you will get a leak from this area. Can you do a write up on the water pump replacement. I will pm you so we can talk. I have all the parts that I will be replacing when I do my water pump(need the water pump). I have all hoses and belts. Need to know which
    thermostat
    to buy(name brand). Also I will be replacing my radiator(I have a lifetime warranty), my power steering pump(making noise and I also have a
    lifetime warranty) along with the power steering hose. What else can I replace sinse Im going to be in here. Is the timing belt a good idea to
    replace
    since you are there. My Caddy has 245,324 original miles. I will also need to flush the coolant system. what do you recommend I use to flush the
    system. Also do you recommend using the gm coolant tabs or should I use an aftermarket solution that is basically the same material? NEED HELP
    Thank You
    Aug 2014
    6
    Thanks Felix, your info will be really helpful, appreciate the photos too. Thanks again
    Hi Caddy1983, this is the first bit of bother Ive had with my cadi. Unfortunately I live in New Zealand so a lot of parts etc have to be sourced from USA. I imported the car from Florida 10 years ago and really not
    too sure how many more miles I'll get from the motor. For now, i'll try get this water pump replaced (which Im going to have to get from USA) and see how I go from there. Thanks for replying with your information too, greatly appreciated
  8. Remove Advertisements
