Results 1 to 12 of 12
Thread: Ride Height 1969 DeVille Convertible
    HansH is offline Cadillac Owners Member
    Automobile(s): Deville Convertible
    Jun 2014
    22
    What is the original ride height on a 1969 Convertible?
    My car is about 1/2" lower on the drivers side, so I`ll need some new shocks and springs and I`m woundering if I should go for some lowering kit or maybe air suspension
    cadillacmike68's Avatar
    cadillacmike68 is offline Cadillac Owners Connoisseur
    Automobile(s): 68 DVC, 96 FLTWD Brg, 09 STS N* Platinum, 11 CTS Premium
    Jan 2005
    Left the desert - Back in FL
    56
    1,303
    Re: Ride Height 1969 DeVille Convertible
    Get air shocks. the shop can run the valve to the frame behind the rear bumper so you can fill or let out air as needed to keep it level.
    Jun 2014
    22
    I already have air shocks, but they are leaking..
    But the car is lower on the drivers side both front and rear, so I would like to do something all around.
    Havent decided if I should go for air bags, rear air shocks or just fixed lowered springs and absorbers yet..
  5. #4
    Jan 2005
    56
    1,303
    You might want to get 4 new springs and two new rear air shocks. Shock do not hold up the car, the springs do this. The exception is air shocks. They help, but need the springs for most of the work.
  6. #5
    Jun 2014
    22
    So, since I already have air shock in the rear (which are leaking, so the car is alot lower on the rear than in front..) and are considering to buy lower springs/shocks, I could need to know what the height is suposed to be original.
    Hence the posted question..
  7. #6
    Jun 2014
    22
    Nobody who knows?
  8. #7
    CBodyFan is offline Cadillac Owners Fanatic
    Automobile(s): NONE
    Dec 2009
    188
    Quote Originally Posted by HansH View Post
    Nobody who knows?
    That is really a personal decsion: do you want a lowered car or do you want the car restored to its original ride height and handling? You will have fewer issues, and a more valuable car, if the suspension is restored properly. On the other hand if you like the look of a lowered car that is your choice. No one can really anwer that question for you.
  9. #8
    Jan 2005
    56
    1,303
    ^^^ My sentiments as well. Resale value will go right down if the car ls lowered, and it will probably introduce other issues as well.
  10. #9
    Jun 2014
    22
    The car dont have the original paint, carb, intake +++, so it will never be 100% original anyway.
    Thats the reason I bought it.
    But I guess it should`nt be 1/2" lower on one side, compared to the other?
    And once more. What is the original height on the rear?
    Since the rear shocks are broken, it looks like I have 3 grown men in the rear seats, two dead bodies and 5 barrels of beer in the trunk..
  11. #10
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    15". I just took a walk outside to measure my cars and every one was 15" to the bottom of the rear bumper. Very unscientific but my '70 Coupe conv is 15" on flat tires, my '70 Impala conv is 15" with full tires and my '77 fleetwood is 15" with full tires. I suppose the Coupe would raise 3-4" with air in the tires. When I measure a vehicle I measure everywhere, rockers, wheelwells, bottom of rear quarter etc. I usually try to get the rear to match the front more or less. The leaking shocks or lines will have to be addressed before you can do much adjusting. If the car will not sit level from side to side then it will have to have new springs.
    I put new stock type springs on my 70 Impala and it sits higher than a hot rod should but I'm afraid if I lowered it that I would lose too much ride quality. These old cars were made to roll over bumps on rough roads and dirt roads. In my part of the country we still have the rough roads and it's nice to have the spring travel to soak up the bumps.
  12. #11
    Jun 2014
    22
    Thank you, cadillac_al!
    Now I have some meassurements to compare
  13. #12
    aaron.hudacky's Avatar
    aaron.hudacky is offline Cadillac Owners Member
    Automobile(s): 70 Eldorado, 78 and 79 Coupe deVilles, 2008 Subaru STI
    Jul 2014
    San Diego
    41
    62
    HansH,
    The 1970 Cadillac factory shop manual says: "Measure distance from top of rear axle housing straight up to lower underside surface of frame. Rear standing heights should be equal within 1/2" on both sides of car. If heights are unequal, spring that checks below specifications must be replaced."
    The deVille convertible with automatic level control should have 5-3/4" to 6-1/2" clearance. Cars without automatic level control should have 5-15/16" -6-11/16" axle housing to frame clearance. The manual states this check is to be done with spare tire and jack in place and a full tank of fuel.
  • You may not post replies
