removing rocker trim on 80 coupe deville
Results 1 to 4 of 4
1985-1996 Fleetwood and Brougham Forum Discussion, removing rocker trim on 80 coupe deville in Past Cadillac Vehicle Discussion; Does the trim just pop off if anybody knows please need a help thanks...
    Laclover84 is offline Cadillac Owners Member
    Automobile(s): 1980 cadillac coupe deville
    Aug 2013
    hutchinson Ks
    32
    54
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,395
    There are hex head screws on the underside, Phillips on the top. You will also have to undo at least 3 screws that go up each wheel well chrome to slide it out from behind the chrome. I highly recommend kroil oil (penetrant) for getting the screws out of the wheel well chrome. Spray then undo the rest of the screws then do the wheel well screws. Also, the Phillips have a tendency to strip. Have a dremel with cutoff wheel at the ready and a steady hand.
    1980coupe's Avatar
    1980coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 78 CDV, 79 CDV delegance, 80 CDV, 80 FWB 2dr delegance (rip)
    Jan 2009
    El Paso, TX
    39
    1,150
    Re: removing rocker trim on 80 coupe deville
    There's only screws on bottom, NONE ON TOP, unless it's a rocker trim off of a Brougham Coupe, then you'll have the screws on top. But there is only bottom screws and also, NONE on the side like mentioned above now this only applies to the trim under the door, the long thin one. If you're removing the rear trim and front, then you'll need to undo at least one side screw for the wheel well trim to slide out both front fender rocker and rear quarter panel rocker....
    Aug 2013
    hutchinson Ks
    32
    54
    thanks for the info
  7. Remove Advertisements
