Page 1 of 3 123 LastLast
Results 1 to 15 of 34
Thread: Impala SS Steering box on 94 Fleetwood?
    Poda is offline Cadillac Owners Fanatic
    Automobile(s): 94 Fleetwood Base, 94 Fleetwood Livery-no vinyl top in sight
    Jan 2012
    Toronto, ON
    40
    286
    Well, I have play in the steering box side to side as observed at the pitman arm, so it's time for a reman or new steering box. I've wanted to tighten up the steering on the blue car for a while in prep of the large HP and performance increases it's going to get, so now's the time- I know the Impala SS steering box has a closer ratio, but is it a direct replacement for the stock box I have in there now?
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,397
    Quote Originally Posted by Poda View Post
    I think some of these caddys had variable ratio steering though...not exactly sure how that works...I imagine you'd have some sensor wires to plug.
    Jan 2012
    Toronto, ON
    40
    286
    Re: Impala SS Steering box on 94 Fleetwood?
    Mine has variable, but I won't mind if I lose it. Pretty sure the sensor is at the column and the VES applies different pressures at the pump, but I'm not sure. Either way, there's a mod that can be done at the sensor on the column to put the pump into minimal assist all the time, which I was meaning to do on this particular car anyway.
  5. #4
    Aztec ETC ECS's Avatar
    Aztec ETC ECS is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC ECS#533, '05 Escalade, '05 AWD Magnum, '74 455 OLDS
    Feb 2012
    NYC
    50
    1,948
    I believe you will also need the longer pitman & idler arms from the Impala to achieve the correct amount of travel if it is a tighter ratio.
  6. #5
    Stingroo's Avatar
    Stingroo is online now Cadillac Owners 10000+ Posts
    Automobile(s): '92 Caprice Wagon LS1/T56 | '01 Buick Century | '95 Lexus LS400
    Jun 2009
    Vero Beach, FL
    26
    18,419
    The pitman arm is the same between the 2.5 (well, 2.7) Impala SS/9C1 steering box as it is for the standard 3.5 turn B-body box.
    If your new box doesn't already COME with a pitman arm, remember that the torque on that nut is high. 185 ft.-lb. is spec.
  7. #6
    Jan 2012
    Toronto, ON
    40
    286
    Awesome.. so aggregating all the posts, I just want to confirm what I need for the swap:
    SS/9C1 box - bolts in
    Pitman arm if not with the steering box
    SS/9C1 Idler arm
    Lookin' forward to it
  8. #7
    Dec 2010
    St. Louis, MO
    6,397
    I did not know you need the idler arms
  9. #8
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,984
    No difference with the idler arm.
  10. #9
    Jan 2012
    Toronto, ON
    40
    286
    That's even better.. Wouldn't happen to have a spare steering box would you Jay?
  11. #10
    Stingroo's Avatar
    Jun 2009
    Vero Beach, FL
    26
    18,419
    Yeah I was about to say... don't think you need a different idler arm.
    Poda - Rock Auto has them for a pretty decent price. I'll be getting one for my wagon while the engine is out (here goes the "While it's out...." list!)
  12. #11
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,618
    Actually...there is a difference in pitman arms...but which one you need is decided by the car's suspension. If your 94 has a steering dampener, the pitman arm would be different then a car without the steering dampener like the Impala. You can see a difference in length and level between the two pitman arms. Worst case is that you have to take off your current pitman arm and use it on the new box like I did.
  13. #12
    Jan 2012
    Toronto, ON
    40
    286
    Good to know. Now if I lower my suspension in the future, will I need different idler/pitman arms?
  14. #13
    Stingroo's Avatar
    Jun 2009
    Vero Beach, FL
    26
    18,419
    Nope.
    If you go CRAZY LOW, your tie rods will hit the frame, but... you can notch for that.
    I sit about 3.5 inches lower than stock in the wagon, and my wheels/tires are another .2 shorter than stock, and I have no troubles. Nothing hits, rides smooth, looks great. I will say though, I removed my factory bump stops. I have never heard my control arms hit anything, and believe me - I drive the SHIT out of this car - but I will eventually put a shorter set of bump stops in, just in case... (or when I go lower. When, not if.)
    Same car, pretty much, so... relevant:
    My buddy Tim is lower than I am. His tie rods hit his frame over large bumps. He needs to notch:
  15. #14
    Jan 2012
    Toronto, ON
    40
    286
    Stingroo -I love the rideheight on the wagon - what shocks/springs did you use to achieve it?
  16. #15
    Stingroo's Avatar
    Jun 2009
    Vero Beach, FL
    26
    18,419
    Easy.
    Shocks - Monroe Severe Service 550012 and 550013 F/R.
    Some guys here say they're too firm and rattle your teeth out. I say, that just means your roads suck.
    Front springs are spec for an F-body I believe. Moog 5662.
    Rear springs are for an A-body wagon, Moog CC501.
    Car rides great. Not sure what you'd use for your rears, but you can use the same front springs for sure. The whole setup was about $130 SHIPPED from Amazon.com. Way better than $300+ for an "Impala SS" lowering kit from most major companies. I'm too poor for that.
  • You may not post replies
