HEI connections
Results 1 to 2 of 2
1985-1996 Fleetwood and Brougham Forum Discussion, HEI connections in Past Cadillac Vehicle Discussion; First post here. I'm putting a Performance Distributors HEI on my 68 SDV, and need some help figuring out where ...
    Earl Cad is offline Cadillac Owners Member
    Automobile(s): 1968 SDV
    Jul 2014
    Southern Wisconsin
    3
    HEI connections
    First post here. I'm putting a Performance Distributors HEI on my 68 SDV, and need some help figuring out where to run the connections.
    How do the following wires connect to the new distributor:
    The 18ga. black/white wire from the AC compressor clutch solenoid ?
    The 18ga. yellow wire from the R post on the starter solenoid ?
    The 20ga. white wire which runs to the ignition switch ?
    Thanks.
    Aztec ETC ECS's Avatar
    Aztec ETC ECS is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC ECS#533, '05 Escalade, '05 AWD Magnum, '74 455 OLDS
    Feb 2012
    NYC
    50
    1,948
    Re: HEI connections
    For HEI, you need 12 volts with ignition on & cranking.
    The the 20ga. white wire which runs to the ignition switch may not be hot while cranking.
    The 18ga. yellow wire from the R post on the starter solenoid is hot while cranking, but I think the voltage is cut down.
    I'm not sure about the 18ga. black/white wire from the AC compressor clutch solenoid.
