1990 Brougham "Hub-In-Rotor" conversion
Results 1 to 13 of 13
Like Tree3Likes
  • 1 Post By MoistCabbage
1985-1996 Fleetwood and Brougham Forum Discussion, 1990 Brougham "Hub-In-Rotor" conversion in Past Cadillac Vehicle Discussion; Im considering converting from the factory hub-in-rotor spindle setup to a later style setup. Anyone have any experience/opinions on this ...
    Strickland is offline Cadillac Owners Member
    Automobile(s): None
    Dec 2012
    32
    71
    Im considering converting from the factory hub-in-rotor spindle setup to a later style setup. Anyone have any experience/opinions on this or
    know which model's spindles/front ends are compatible for this? For example.......does anyone know if a big body caddy spindle/hub will fit
    the broughams?
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,423
    Re: 1990 Brougham "Hub-In-Rotor" conversion
    There's probably nothing stock that will be a direct fit. FWD cars use a completely different setup and trucks generally have different parts too. There's no real benefit to changing what's already there.
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,880
    The parts already exist. Contact Bill Harper (Navy Lifer) over on the Impala SS Forum. TCE also offer custom hubs that will accept slip on rotors in sizes from stock to huge.
  5. #4
    Jun 2003
    Canada
    6,423
    Aftermarket to the rescue.
  6. #5
    larryinalabama is offline Cadillac Owners Connoisseur
    Automobile(s): 1990 Brougham, 1990 Brougham d'elgance 1979 Coupe
    Dec 2013
    1,043
    Sounds like a step backwords, the old style never warp, the floating rotors warp when you put them on.
  7. #6
    Sep 2006
    Ontario, Canada
    44
    7,880
    A 15x1.25" rotor does not warp. A slip on rotor on a Civic does, though!
  8. #7
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    28
    26,325
    Rotors don't warp, period. Ask any brake manufacturer.
    highonchai likes this.
  9. #8
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,604
    What do you mean? I've personally turned warped rotors. Two feet drivers for example...
  10. #9
    Sep 2006
    Ontario, Canada
    44
    7,880
    Pretty sure that was facetious.
  11. #10
    Sep 2010
    East Boston MA.
    28
    26,325
    Quote Originally Posted by csbuckn
    You've turned rotors with uneven wear side to side. Rotors don't actually "warp" (change shape) into an untrue state.
  12. #11
    the APEMAN is offline Cadillac Owners Enthusiast
    Automobile(s): 1980 FBC
    Mar 2010
    54
    532
    I was wondering also why anyone would want to do this in the first place.
    Resisted the idea uneven lug nut torque would lead to wacked rotors and lumpy brakes for a while. Finally I learned this was true.
  13. #12
    Jan 2008
    Minneapolis
    5,604
    Bigger bearing, less weight, more rotor options, different bolt pattern... The reasons are there for the more extreme conditions but, for daily driving, it'd be tough to justify the move.
    Moist, your reply makes sense but I think most people will call uneven wear the same as warped. Either way, the rotors would need to be turned.
  14. #13
    Sep 2010
    East Boston MA.
    28
    26,325
    Yes, warped is the commonly used term, just misleading.
  15. Remove Advertisements
