timetraveller
Results 1 to 9 of 9
Like Tree3Likes
  • 1 Post By carnut
  • 1 Post By the APEMAN
  • 1 Post By MoistCabbage
1985-1996 Fleetwood and Brougham Forum Discussion, timetraveller in Past Cadillac Vehicle Discussion; I have a 1982 cadillac fleetwood de-elegance which has the LSD, THE car has been standing in the garage for ...
    timetraveller is offline Cadillac Owners Member
    Automobile(s): 1982 fleetwood brougham de-elegance
    Apr 2014
    75
    timetraveller
    I have a 1982 cadillac fleetwood de-elegance which has the LSD, THE car has been standing in the garage for eight years until last year when it was hauled out and recomishened. When i got it on the road i found this heavy juddering on tight corners so after reading your forum on the lsd i drained and changed the oil, now i have only had the car out once since then and done about 50 mile but does anybody know how long it takes before the juddering disapears.
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,939
    Re: timetraveller
    You need to add a bottle of GM posi additive. You can buy it at any GM dealer. The parts guy will know exactly what I'm talking about.
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,614
    The noise probably won't go away. I'd bet the damage is done. Was there fluid in the rear when you changed it?
    Apr 2014
    75
    Re: timetraveller
    hello, the new oil i used was olie oil 75w/90 which has the additive already, they also said that if it was not working i might have to add a little bit more additive which they suggested using there own brand and only adding 1ounce at time. Do you think there is any difference between theirs and GM, the one handycap i have it takes a little bit longer to get things because i do not live in the USA but in the UK.
    thanks for your help and i will keep in touch MN
    hello, the diff has allways had oil in it but i did not know was that the car had a LSD in it until the garage went to check the wheel bearing and they had to go into the diff to losen the drive shift, because we thought the juddering was the bearing so after reading the cadillac forum we bought olie oil 75w/90 which has the additive in and put that in the diff. So lets hope the oil works.
    many thanks and i will keep on touch. MN
    Sep 2006
    Ontario, Canada
    44
    7,939
    Re: timetraveller
    Yes, you need the GM additive. Stop by the Cadillac/Corvette dealer.
    Feb 2003
    california
    69
    6,663
    Re: timetraveller
    When I was 20, I wrote service repair orders at a Pontiac dealer. We changed the LSD fluid in Pontiac Trans Ams often and it's main ingredient was "sperm whale" oil. I thought at first it was "whale sperm" oil! got me thinking who does this job? How's this accomplished? Well finally got that figured out!!
    talismandave likes this.
    talismandave's Avatar
    talismandave is offline Cadillac Owners Master
    Automobile(s): 1980 Eldorado, 1974 Talisman, 2004 Volvo C70,
    Mar 2012
    Madison WI
    57
    7,893
    Re: timetraveller
    Quote Originally Posted by carnut View Post
    "We're gonna need a bigger boat."
    the APEMAN is online now Cadillac Owners Enthusiast
    Automobile(s): 1980 FBC
    Mar 2010
    54
    561
    Re: timetraveller
    They put posi rear axles in '82 Fleetwoods???
    csbuckn likes this.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Gotta keep those 4.1s from melting one tire at a time!
  12. Remove Advertisements
