safe to paint my alternator?
Results 1 to 14 of 14
Like Tree2Likes
  • 2 Post By YoshiMan
1985-1996 Fleetwood and Brougham Forum Discussion, safe to paint my alternator? in Past Cadillac Vehicle Discussion; I know that may seem like an odd question, but my junkyard CS144 was previously painted black (works fine btw) ...
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,397
    I know that may seem like an odd question, but my junkyard CS144 was previously painted black (works fine btw) but half the paint has fallen off and its got a purple spraypaint spot on it from the junkyard for warranty. I'm wondering if I can repaint it again so it doesnt look like I have a ratty junkyard alt in my car.
    dukeofny's Avatar
    dukeofny is offline Cadillac Owners Member
    Automobile(s): 1981 coupe deville
    Sep 2012
    va
    32
    Re: safe to paint my alternator?
    I have painted them before with no problems, try getting the paint off with some brake cleaner first tho
    deVille33 is offline Cadillac Owners Connoisseur
    Automobile(s): 1977 Coupe (blue), 1977 Coupe (yellow), 1977 Coupe (green)
    Mar 2006
    Western Massachusetts
    1,493
    Acetone works better.
    CadillacPimpinNOLA is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 Fleetwood 1968 coupe DeVille
    Jul 2009
    Metairie/New Orleans,LA
    33
    1,152
    yes you can paint, powder coat, chrome or polish your alternator
    The-Dullahan is offline Cadillac Owners Master
    Automobile(s): Orange And Purple Lights.
    Jun 2009
    Sitting on The Levee
    29
    6,632
    Quite. In fact, basically all of my cars' alternators look different. The trucks have a spotless and a grungy aluminium housing respectively, the Cadillac has a polished one, the Pontiac has a shiny black one.
    Fifty9cadillac is offline Cadillac Owners Member
    Automobile(s): 1959
    Mar 2014
    36
    Definitely scrape off, sandoff, blast off, or use acetone to get all of the old paint off. That way it will spray on clean and maintain a nice finish.
    YoshiMan's Avatar
    YoshiMan is offline Cadillac Owners Fanatic
    Automobile(s): 1975 Coupe Deville D'Elegance
    Oct 2012
    Denver, CO
    32
    261
    If I was going to paint one, I would completely disassemble it first and just paint the housings. Not sure I would want to just hose it down with paint with all the innards still in it.
    Benzilla and talismandave like this.
    talismandave's Avatar
    talismandave is offline Cadillac Owners Master
    Automobile(s): 1980 Eldorado, 1974 Talisman, 2004 Volvo C70,
    Mar 2012
    Madison WI
    58
    7,894
    Or stuff rag scraps in openings and mask the pulley surface and you would probably be OK.
    Just make sure to get them all out again!
    Jul 2009
    33
    1,152
    if you decide to pull it completly apart id recommend an alternator shop disassemble and reassemble it for you...i watched my guy do mine when rebuilding mine and for the most part its straight forward but he did have a wire inserted in the back of the case and once together he removed it so it holds something in place to work right.
    Dec 2010
    St. Louis, MO
    6,397
    I decided not to go that far I just sanded and painted it. I'll put up pictures later
    Jun 2009
    29
    6,632
    Quote Originally Posted by CadillacPimpinNOLA View Post
    That is for holding the brushes in.
    The main problem I see people have with alternator is forgetting how they had the four bolts lined up.
    That's why you should always mark the housing.
    Another problem is tightening these bolts. They are very weak and only have to be snug enough to hold. Together.
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,496
    It's usually more of a problem loosening the bolts, especially if it's been together for a while.
    There'd be mo problem painting it but unless you plan on doing it by hand any overspray you see inside it or on parts that aren't supposed to be painted will probably look just as bad as what's there now.
    larryinalabama is offline Cadillac Owners Connoisseur
    Automobile(s): 1990 Brougham, 1990 Brougham d'elgance 1979 Coupe
    Dec 2013
    1,090
    A cheap foam brush and a 6 pac can make stuff look new again, I painted my brake master cyl that way, turned out real nice, but it took a little time and about 3 foam brushes.
  16. #14
    Dec 2010
    St. Louis, MO
    6,397
    Sanded and painted it spent a lot of time on the part you see (right side) and not so much time on the left side. At least the part you see looks nice. The rest looks about like it used to, except with more paint
  17. Remove Advertisements
