1980 fleetwood with no turn signal - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 26 of 26
Like Tree2Likes
1985-1996 Fleetwood and Brougham Forum Discussion, 1980 fleetwood with no turn signal in Past Cadillac Vehicle Discussion; So.... you replaced every turn signal bulb before any flasher! you did confirm each bulb was correct for its socket, ...
  1. #16
    Automobile(s): 1999 BMW 740 Il. 2005 Jag XK8, 1988 Mercedes Benz 300 SE
    Feb 2003
    california
    69
    6,688
    Re: 1980 fleetwood with no turn signal
    So.... you replaced every turn signal bulb before any flasher! you did confirm each bulb was correct for its socket, correct? Meaning a single filament bulb in a single filament socket, dual filament bulb in a dual filament socket.
  2. #17
    804fleetbro is offline Cadillac Owners Member
    Automobile(s): 1980 Fleetwood Broham
    May 2013
    29
    34
    Quote Originally Posted by carnut View Post
    Yes I replaced bulbs before the flasher. Oh my was that the wrong thing to do? Yes I checked to make sure the correct bulb is in its corresponding socket.
    Went to the Cadillac today,( my father's house) still no luck, reevaluated each bulb and bulb housing. Everything is tight and working properly. Except the headlights. All fuses are good, is there any relays that correspond with the headlights? I know they are in working order. Thanks for the replays.
  3. #18
    1980coupe's Avatar
    1980coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 78 CDV, 79 CDV delegance, 80 CDV, 80 FWB 2dr delegance (rip)
    Jan 2009
    El Paso, TX
    40
    1,150
    So now your headlights are out too?
    When mine went out it was a fusible link that melted and caused them not to work. The link is within the wiring leading from the firewall to the radiator support. Which headlight(s) are out? Low beam/high beam/both? Each one is a different wire and has its own fusible link. I then replaced it with a inline fuse and no issues since.
  5. #19
    May 2013
    29
    34
    Quote Originally Posted by 1980coupe View Post
    Thanks for that info 1980coupe, its like this when I pull the headlight knob, all of the lights work except the headlamps themselves. If I turn the high beams on, only the low beam headlamps work.
  6. #20
    1980coupe's Avatar
    Jan 2009
    El Paso, TX
    40
    1,150
    Quote Originally Posted by 804fleetbro View Post
    It should be the other way, if you're turning high beams on yet your lows are coming on then basically you're actually turning high beams off. One way to be certain is to take a look at center of your dash, do you see a lil blue indicator? If so, that's saying your high beams are on, but are they really?
  7. #21
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    It's starting to sound more like the high/low switch now. If it was on the floor it would be simple; yours is probably on the column and the switch is mounted on the column.
  8. #22
    May 2013
    29
    34
    This is with the headlights turned on.
    and this on is with the hi-beams turned on.
  9. #23
    May 2013
    29
    34
    Its hard to see the indicators in the day
  10. #24
    Corey468's Avatar
    Corey468 is offline Cadillac Owners Fanatic
    Automobile(s): 1976, 1994 Cadillac Fleetwoods, 1996 Lincoln Town Car
    Sep 2012
    Walnut, CA
    22
    204
    Okay, so just to clarify here, from the pictures it looks like the typical parking lamp and low-beam lights are functioning. As 1980coupe stated, is there a blue light illuminated on the dash when you have the headlight knob pulled all the way out and the turn-signal high-beam stalk, pushed forward? Also, it appears that you have a few bulbs out in your parking lights, the outer ones on both sides. I believe that all of the front parking amber area should be illuminated, like this http://www.mcsmk8.com/80-BRHMB/HR/CARS-21.JPG
  11. #25
    May 2013
    29
    34
    Quote Originally Posted by Corey468 View Post
    Yes the blue "hi beam" light is illuminated on the dash. As far as the parking lights, they were illuminated also. But I will.check again.
  12. #26
    May 2013
    29
    34
    No hi-beam indicator on the dash anymore
    Well thanks everyone who tried to help me, I will be taking the Fleetwood to the shop monday to see if they can determine what's going on. Once again thanks for the help.
  13. Remove Advertisements
