Quadrajet differences between years question
Results 1 to 11 of 11
1985-1996 Fleetwood and Brougham Forum Discussion, Quadrajet differences between years question in Past Cadillac Vehicle Discussion; I want to rebuild a Quadrajet for my 1979 deville before I get into putting the EFI I got for ...
    ferrisworld is offline Cadillac Owners Fanatic
    Automobile(s): 1979 Sedan Deville
    Feb 2005
    Sacramento, CA
    445
    I want to rebuild a Quadrajet for my 1979 deville before I get into putting the EFI I got for it on. It has a quadrajet now and I want to learn about the old school stuff before I get into the new stuff. I want to pull one from pick n pull to build so I don't have to disable the car while I build the carb. I have access to a 77 eldorado, and a 75 fleetwood. Obviously the 77 will be the best match, and I read that 76+ castings are the ones people are after. I also read that in 1979, they replaced the plastic limiting caps with steel ones that are hard to remove, so perhaps that would make the 77 carb an even better option?
    Thanks
    Jeff R's Avatar
    Jeff R is offline Cadillac Owners Enthusiast
    Automobile(s): 1970 Coupe De Ville//Cessna 172
    May 2013
    St. Louis
    47
    547
    Re: Quadrajet differences between years question
    Good idea getting a junk one to work on. I've done that a couple of times too. No surprises when you start working on the one that counts.
    Jeff
    Feb 2005
    Sacramento, CA
    445
    Is it bad if the air flaps have surface rust? Also the secondaries are stuck closed. Should I skip it and look for another?
    rodnok01's Avatar
    Feb 2012
    NC
    6,719
    Yes and yes... If the secondaries are stuck the bushings on shaft may need replacing. If you just want to take a couple apart fine. To be honest Q Jet's fairly simple to rebuild. I'm sure you can pick a book up on the cheap on rebuilding them.
    Try amazon also
    http://www.ebay.com/itm/ROCHESTER-CA...f6a08b&vxp=mtr
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,127
    Yeah, that ^^^^
    ........ and when you get Doug Roe's book, study up on secondary metering rods, rod hangers, secondary air valve operation, jet sizing, and primary jet needle operation.
    You can make a full-time hobby of finding QJs and stockpiling internal parts - the possibilities for individual tuning are literally infinite.
    Feb 2005
    Sacramento, CA
    445
    I got the book a while ago, so I have that. I'll just keep my eyes out for a better 76-78 carb. The whole car looked like it had been weathered pretty severely. Even the cashier at pick n pull said he wouldn't buy the carb if it was him.
    Thanks guys.
    rodnok01's Avatar
    Feb 2012
    NC
    6,719
    You need to figure out what numbers you can use and look for those. Junk Q jets a dime a dozen back in the day. Think i finally junked all my old carbs last years except for any that were being used. Dont limit your search to cadillacs if you just want to mess around with them.
    Feb 2005
    Sacramento, CA
    445
    Well they want $50 for one, and I want to put it in my Cad.
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    Lots of Qjets on ebay too. That's where I get most of mine. I have never paid more than $50 for one and I usually can find a clean one for that price.
    Angry Matt's Avatar
    Angry Matt is offline Cadillac Owners Enthusiast
    Automobile(s): (2) '81 FWBs, '86 Cutlass Supreme
    May 2009
    Limerick, PA
    38
    690
    What's the difference with the California model? Is there something to be lost by using this version?
    rodnok01's Avatar
    Feb 2012
    NC
    6,719
    There are high altitude versions, CA versions(can have additional features and are tuned specifically to pass CA regs) which I avoid like the plague...
  14. Remove Advertisements
