Results 1 to 8 of 8
Thread: 1995 Fleetwood Wipers. Failed delay, Working low with a pause, and high parks. *vid*
    AshleyA is offline Cadillac Owners Member
    Automobile(s): 1995 Fleetwood B.
    Apr 2014
    29
    8
    Hello there. Please refer to the video below. I would like to start off with idea that I have been around the internet for a few days with this, and the wiper board/pulse modules that everyone replaces looks nothing like mine. I have a flat connector with a different shaped board.
    Like the titles says, The delay does not work at all, the "low" setting works but has a strong pause in it half way up the windshield (not a slipping shaft), and in high the wipers keep parking and activating over and over (part of the video).
    I believe I have isolated the parking issue, I just dont know if the pull is connected to a relay or something. Please take a peek at the video.
    Apr 2014
    29
    8
    Re: 1995 Fleetwood Wipers. Failed delay, Working low with a pause, and high parks. *v
    This must be a tricky one. 53 views and no answers!
    Apr 2014
    29
    8
    Running a dedicated ground wire did nothing.
    I changed the board out with the old one, I now have less issues, like low always works, but everything else is fairly intermittent now, including delay. Washers are completely dead though. Do the washers go through the motor board at all or is it a seperate circuit?
  5. #4
    Apr 2014
    29
    8
    Lots of help here...
  6. #5
    rodnok01's Avatar
    rodnok01 is online now Cadillac Owners Master
    Feb 2012
    NC
    6,702
    The washer circuit goes through the motor head. When you activate washers it turns on the wipers and sends a pulse to the pump for certain amount of time. When the washers stop the motor head keeps the wipers active for certain amount of strokes than applies park the the motor.
    Does your model have Rain sense, the standard wiper motors have a wide flat connector and rain sense have 2 rows and a narrow but thicker plug. Should be the same for your vehicle.
    You need to get a wiring diagram.
    I think you have an intermitant issue with the motor itself, probably a bad contact, posssibly a flaky switch but doubt it.
    The reason you haven't had any responses is most people just R&R... and stop R&R when it starts working again.
  7. #6
    Apr 2014
    29
    8
    I see. I try to keep posting updates as I find new things.
    Mine does not have the rain sense. It is a single row connector. Many of the videos and guides I have seen have a squareish plug and a smaller board.
    This is a new motor, and having tried both boards in there, the original works the best (but with different issues than with the original motor.)
    My next step is to pull the plugs and clean them. When I installed the motor I took both boards and sanded the contacts clean with emery cloth, so I know its not the male end.
  8. #7
    Apr 2014
    29
    8
    I pulled the plug and ran a quick pipe cleaner through it. It now works better. The intermittent will work for a minute or two then go back to a low like setting.
  9. #8
    Classic L is offline Cadillac Owners Fanatic
    Automobile(s): 95 Concours / 88 Broughm D'el / 76 Coupe D'el
    Aug 2012
    Boston, MA USA
    114
    I read your thread a while ago but could not offer any information on the subject. I would like to offer some encouragement and say I'm glad to see you are hanging in there with this and do seem to be making some headway. Don't get discouraged. If you do not have the service manual for your vehicle, it's a good investment, especially if you plan to do whatever work you can yourself. You know what? I have a service manual for my 95 Concours. I'll look in their troubleshooting tree and see if they have anything that seems related to what you are experiencing. Here's hoping to more sunny days than rainy ones in your future anyway!
  • You may not post replies
