1968 Brake Issue
Results 1 to 5 of 5
1985-1996 Fleetwood and Brougham Forum Discussion, 1968 Brake Issue in Past Cadillac Vehicle Discussion; My 68 deville has drum brakes and it's acting weird when I first begin to slow down. Most of the ...
    sams2100 is offline Cadillac Owners Fanatic
    Automobile(s): 1968 DeVille Conv, 1999 DeVille, 2003 Escalade
    Oct 2008
    125
    1968 Brake Issue
    My 68 deville has drum brakes and it's acting weird when I first begin to slow down. Most of the time when you first begin to slow down, the car will jerk left (assuming the left front wheel is breaking before the right), and sometimes it will give a slight jerk to the right. Rarely it will jerk back and forth a time or two while beginning to slow down.
    After that initial swing to the left or right, it slows down as normal. Any ideas what might be causing this?
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    Re: 1968 Brake Issue
    Probably leaky wheel cylinders. Does your brake fluid stay full? I have had a leaky one on my 70 Impala for a few years now. It locks up the rear wheel on the first few stops then smooths out. I just keep filling the master cylinder every couple weeks or so. If you are losing fluid too fast then it will have to be changed.
    outsider is offline Cadillac Owners Connoisseur
    Automobile(s): 87 Brougham, 1969 Calais, 95 FWB, 05 CTS, 07 SRX
    Sep 2009
    Buxton, Maine, United
    33
    4,147
    ^ Yeah, what Al said. Easy enough to swap out but you will have to bleed the brakes after.
  5. #4
    Feb 2003
    california
    69
    6,607
    I presume that because its that old, you've replaced all the wheel cylinders and hoses to them recently. If not, then do so! I wouldn't drive it till the brakes (breaks!) were overhauled. I've owned many old cars and I always inspect and/or fix brakes first before I use the car daily. If the brakes break while driving you now have an old "wrecked" car!
  6. #5
    Feb 2007
    Maine
    55
    3,310
    ^ Very true. You don't want to be riding around with 40 year old brake hoses and other parts. I would hope it has been maintained over the years. But, it is fairly common for old cars that sit around a lot to have a leaky wheel cylinder. In a perfect world it should be replaced properly; that's your call I guess. For me, I have too many cars and the maintenance gets spread pretty thin.
  7. Remove Advertisements
