1973 Wind Shield Wiper Motor ?
Results 1 to 5 of 5
1985-1996 Fleetwood and Brougham Forum Discussion, 1973 Wind Shield Wiper Motor ? in Past Cadillac Vehicle Discussion; The wiper motor clicks when turned on in my 1973 Cadillac. I took the motor out of my other car, ...
    coodeville is offline Cadillac Owners Member
    Automobile(s): 1970 Couple DeVille 1973 M&M Olympia 1988 Brougham Flower Ca
    Apr 2011
    32
    The wiper motor clicks when turned on in my 1973 Cadillac. I took the motor out of my other car, which is the same, and put it into the car. Again, it would not work in the '73 but clicked. Any suggestions ? All three bolts are in place to hold the wiper motor in place.
    deVille33 is offline Cadillac Owners Connoisseur
    Automobile(s): 1977 Coupe (blue), 1977 Coupe (yellow), 1977 Coupe (green)
    Mar 2006
    Western Massachusetts
    1,493
    Re: 1973 Wind Shield Wiper Motor ?
    Do the arms move at all? The click may be the solenoid which pulls the lock off the cam for the windshield washer.
    Pull the cover off the control cap and using a test light or voltage meter, check that you are getting a signal from the switch to the motor. Your switch could be your problem.
    Apr 2011
    32
    The arms only move when disconnected from the motor.
    Mar 2006
    1,493
    Check that you are getting current from the switch to the motor.
    Apr 2011
    32
    I checed. Im getting current at the center terminal of the motor.
  8. Remove Advertisements
