Right turn signal wont cancel
Results 1 to 4 of 4
1985-1996 Fleetwood and Brougham Forum Discussion, Right turn signal wont cancel in Past Cadillac Vehicle Discussion; Working on my parents 1990 Fleetwood Brougham D'Elegance. The right turn signal won't cancel. Removed wheel and everything down to ...
    oregonk5 is offline Cadillac Owners Member
    Automobile(s): My 95 Deville, parents' 90 Fltwd Brougham. Many more!
    Jan 2012
    Oregon
    24
    Removed wheel and everything down to the switch. Switch looks ok (I had replaced it a couple years ago) but I decided to replace it anyway..thinking maybe weak spring.
    Tested it on with the front end in the air and seemed to work ok. Reassemble the whole column and go to road test and right turn still won't cancel. Left works just like it should.
    Any thoughts?
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,905
    Re: Right turn signal wont cancel
    You have a broken turn signal spring, or, it has popped out of it's holder. There are two different springs. You can see one red one in this pic, and a bit of the other one at the top.
    Here's how to replace them:
    http://www.grail-ss.com/TurnSignalSpringReplacement.htm
    Jan 2012
    Oregon
    24
    Thanks but the springs are good....in fact, it's a brand new switch assembly but the old one didn't have broke or worn springs either. I'm going to pull it down tomorrow...I'm thinking it may be a worn horn contact/cancel assy....which of course is discontinued.
    Feb 2003
    california
    69
    6,643
    Is the steering wheel centered as you drive straight on a level road? Never seen a worn cancelling cam so worn to cause this. Have seen springs missing, broken and steering wheel off center many times.
  7. Remove Advertisements
