Results 1 to 10 of 10
Thread: Barbara Ann Learned a New Trick
    sven914's Avatar
    sven914 is offline Cadillac Owners Connoisseur
    Automobile(s): 1989 Brougham d'Elegance, 1985 Fleetwood Brougham *Coupe*
    Dec 2008
    4,256
    I can now remove the ignition key with the engine running, and it stays running. Beyond that, the ignition seems to work properly; engine turns off as it should, the ignition cylinder won't turn without the key, and the key still works in the cylinder.
    Anybody else have this issue? I'm using the factory original Gold Key, so maybe I should retire it for one of my copies.
    talismandave's Avatar
    talismandave is offline Cadillac Owners Master
    Automobile(s): 1980 Eldorado, 1974 Talisman, 2004 Volvo C70,
    Mar 2012
    Madison WI
    58
    7,894
    Re: Barbara Ann Learned a New Trick
    My old 71 Monte Carlo developed that trick in her final years. Wish it had happened sooner, very convenient in Wisconsin winters to warm up the car and be able to take keys with to unlock it!
    If it bothers you switch keys, but it does no harm either way.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    My mothers boyfriends '64 impala did that.
  5. #4
    Robin Banx's Avatar
    Robin Banx is offline Cadillac Owners Enthusiast
    Automobile(s): 1983 FWB (Mac), 1981 SDV (Junkyard Dog)
    Dec 2007
    Vancouver, B.C. Canada
    725
    My 81 SDV also did that and as others have discovered, it is a very useful feature. I suspect worn tumblers in the lock more than the key itself were at fault. I could also turn the ignition off without replacing the key in the lock.
    Cheers.......R.
  6. #5
    Maine88Brougham's Avatar
    Maine88Brougham is offline Cadillac Owners Member
    Automobile(s): 1988 Cadillac Brougham
    Jan 2014
    S. Maine
    21
    47
    I agree with everyone else the Maine winters are very cold and being able to lock the my FWB in the parking lot while it's running is pretty useful
  7. #6
    sven914's Avatar
    Dec 2008
    4,256
    I carry a spare door key on me at all times, so I've never had to worry about the inconvenience of turning off the engine when I make a short trip into a store or the post office.
    But I do have my key ring on a quick release for when I need to move my other car; that's how I found out the ignition key could be pulled out. Being able to just take the key would make that task easier at night.
  8. #7
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,984
    This is very common on GM cars as the key wears (as others have experienced). I've had a few Caprices that did it, and my 65 Impala currently has this feature.
  9. #8
    shrike77 is offline Cadillac Owners Fanatic
    Automobile(s): 1987 Brougham 5.3 Vortec, 4L60E transmission
    Jun 2010
    Montreal, Qc
    39
    334
    I can certify that that trick remained a GM family tradition at least until 2000 (Saturn SL1)
  10. #9
    77CDV's Avatar
    77CDV is offline Cadillac Owners 10000+ Posts
    Automobile(s): 77 CDV, 06 DTS III, 69 FWB
    Mar 2006
    Newbury Park, CA
    45
    10,022
    My first CDV did this. It's just the ignition tumbler and key wearing over time. It does no harm, and if it doesn't bother you, I'd leave it be.
  11. #10
    sven914's Avatar
    Dec 2008
    4,256
    The main thing that was concerning me was; if the key is that loose, how long will it be, before the key/tumblers are too worn down to turn the lock cylinder.
    To avoid further damage to the factory original Gold Key, I did swap it for a redundant copy I have, and it seems tighter in the lock. When I compared the two keys, the original doesn't even look like a key any more (it looks more like a key blank), so I don't even know how it was working in the first place.
  • You may not post replies
