91 Brougham, how to tighten power mirror?
Results 1 to 5 of 5
1985-1996 Fleetwood and Brougham Forum Discussion, 91 Brougham, how to tighten power mirror? in Past Cadillac Vehicle Discussion; Hi all, I'm new to the forum and have a question about my 91 Brougham. The mirror housing on my ...
    Tolk is offline Cadillac Owners Member
    Automobile(s): 1991 Brougham
    Feb 2014
    7
    The mirror housing on my drivers side mirror has been gradually getting looser.
    I can't seem to figure out how to tighten it up.
    If I point the mirror as far up as it goes I can see a couple screws but can't figure out how to get to them.
    Is there a way to pop the mirror out without damaging it?
    Feb 2003
    california
    69
    6,664
    Re: 91 Brougham, how to tighten power mirror?
    I've tightened up a few of these chrome mirror housings. I force the mirror lens in at the bottom and while holding it in, use a small phillips screwdriver at an angle. Yes you can pop the lens off but it requires a bit of talent. There are four pins that engage in the mirror motor pivot head (assuming its an electric mirror ) and it will sound like you broke the mirror when it pops off! try it on a wreck first. If you get the lens off, use blue Locktite on the screws.
    Feb 2014
    7
    Thanks carnut, I'll try it that way in the morning. I really don't want to pop the mirror off, its power and heated
    Feb 2003
    california
    69
    6,664
    Because its heated, there is a tiny wire harness hooked to the glass, easily broken.
    Feb 2014
    7
    Well that was a project. The screws I needed to tighten were the two holding the housing to the arm. Was no way to get to them as the motor was in the way. Ended up taking out the 3 screws that I believe you were talking about and removing the whole mirror/motor assembly which was pretty quick and simple. Putting it all back together on the other hand... I think I would rather change ball joints haha. Managed to get two of the screws back in. Going to need to get creative with the third one.
    Didn't dare try and pop the mirror off the motor ...23 year old plastic and all
  8. Remove Advertisements
