Page 1 of 2 12 LastLast
Results 1 to 15 of 19
Thread: 1980 Coupe deville lsx swap questions?
    Kevo1288 is offline Cadillac Owners Member
    Automobile(s): 1980 Coupe Deville
    Jun 2013
    28
    17
    So I have been building a 5.3 truck motor for some time now, ported heads, tr220 cam, pac springs, ls1 intake manifold, gathered a gt45 t4 turbo along with supporting components.
    My cadi is currently on air ride, I am not sure if you guys remember me posting.
    I did the top end in the car not too long ago but I am not a fan of the 368 at all, nor am I fan of old design SBC motors. So I want to put my 5.3 in the car, already have a stand alone harness made and ready (this will also allow me to upgrade the alternator , I was having an issue with factory alt running the two compressors for the air ride) , I would also like to end up turbo charging it and placing a 4l80e behind it with its own stand alone programmer.
    I know, air ride, lots of horsepower, no traction, whats the point? The car to me is so much different than everything around here and looks sinister as hell laid out. I am just going for wow factory! its my baby.
    So basically here are my questions.
    Is this car a c body or b body or what? What chevrolets/buicks/etc share the same motor mount (frame side) etc as my coupe deville, so I can start researching how I am going to mount it etc.
    Also , what rear end is in my car and do you think I should upgrade to something different? Any larger brake upgrades for this car (lots of power, need to stop!) I am running 17 inch wheels).
    Anyways sorry for the rant or whatever but I am just about ready to have this thing put in and want to cover every basis.
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,618
    The 90-96 cadillac brougham or box/bubble caprice would be your best bet for a motor mount. I'd like the gear you have in the rear end personally but you may want better gas mileage. It's strong enough to handle the power but not much available for upgrades. Pictures?
    Jun 2013
    28
    17
    Re: 1980 Coupe deville lsx swap questions?
    Ok well thanks for the heads up on everything. I would prefer a taller ratio in the rear (turbos like engine load, faster spool with a taller gear than shorter) if mine is short.
    Here are some pics for ya.
    54k original miles, paints faded and discolored but the car is clean clean clean as far as rot goes, any rust on it can be wiped off with the exception of the stain under the pass rear window.
  5. #4
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,985
    It's a C body, renamed D body (long wheelbase B body) in the late 80s. Buy LS mounts for a 77-96 Caprice/94-96 Impala SS.
  6. #5
    shrike77 is offline Cadillac Owners Fanatic
    Automobile(s): 1987 Brougham 5.3 Vortec, 4L60E transmission
    Jun 2010
    Montreal, Qc
    39
    334
    MIght be wrong but aren't these mounts made for the Chevy engines? I thought the Olds mounts were different.
    By the way nice wheels on that Caddy. Thats exactly the kind of wheels I`d like to put on mine too, maybe d-windows instead of the round holes. Won't happen soon though...
    You'd be building the car of my dreams, only missing a stick shift.
  7. #6
    Jun 2013
    28
    17
    Thanks man! They are 17 inch cragar soft 8s, scored them at a swap meet for 40 bucks with tires. The rears are pretty wide to 275's lol. The car needs some very little massaging in certain areas. Its my RAT ROD! , I know the car deserves a paint job and whatnot but leaving it in its original state is just so much more badass to me!
  8. #7
    Jun 2013
    28
    17
    Any idea on what I could do for a fuel pump , or am I just going to have to run an external pump.
  9. #8
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,397
    Quote Originally Posted by Kevo1288 View Post
    I think you will need an external or in tank pump.
  10. #9
    Jun 2013
    28
    17
    I'll figure it out I got all my tubing for the hot side of the turbo kit ready and flanges as well.
  11. #10
    Sep 2006
    Ontario, Canada
    44
    7,985
    Use a 94-96 Fleetwood plastic fuel tank, with the factory sender, and swap in the higher pressure LS pump. Bolt in, factory solution,
  12. #11
    Jun 2013
    28
    17
    Man oh man , I need to learn some more about these cars. I could do this swap in a fox all day but this car is a puzzle to me , thanks for the help guys!
  13. #12
    GDPossehl is offline Cadillac Owners Enthusiast
    Automobile(s): '04 CTS-V
    Feb 2011
    Decatur, GA
    507
    If you're going to be running a turbo, you're going to need more than what a factory fuel pump can provide. I don't know much about 80's cadillac fuel setups, but depending on your power goals, you'll likely need an in-tank setup with aftermarket units. Aeromotive has an array of products to get you where you need to be. Giving their sales team a call would be my advice. Tips for getting crafty with installs can be found with some searching.
  14. #13
    Jun 2013
    28
    17
    I know all this, I just do not what provisions are provided for these cars. I know how much fuel I will need etc. Just didn't know if there were options such as the fuel tank upgrade posted above!
  15. #14
    Jun 2010
    Montreal, Qc
    39
    334
    Quote Originally Posted by jayoldschool View Post
    That's what I did on mine and this is what I was going to recommend. But as it was said, with a turbo you'll need more flow. Some people modify the tank to put 2 pumps inside.
  16. #15
    Sep 2006
    Ontario, Canada
    44
    7,985
    I believe Racetronix makes a high volume pump that will go in the stock sender.
  • You may not post replies
