87 Brougham ECC gone black. after a couple weeks of intermittent working.
Results 1 to 6 of 6
Like Tree4Likes
  • 1 Post By larryinalabama
  • 2 Post By sven914
  • 1 Post By talismandave
1985-1996 Fleetwood and Brougham Forum Discussion, 87 Brougham ECC gone black. after a couple weeks of intermittent working. in Past Cadillac Vehicle Discussion; Well, as is always the case, just as I am getting ready for a drive to Chicago for the auto ...
    talismandave's Avatar
    talismandave is offline Cadillac Owners Master
    Automobile(s): 1980 Eldorado, 1974 Talisman, 2004 Volvo C70,
    Mar 2012
    Madison WI
    57
    7,893
    Well, as is always the case, just as I am getting ready for a drive to Chicago for the auto show, my ECC display has gone black after a few weeks of off and on working.
    For the last few weeks it would work fine unless I took long rides. At some point it would go off. I would park it and the next time I would start it up, a few days later it would be fine again.
    Being winter, I haven't driven it much, and hoped I could live with it until spring when diagnosing it is a bit easier.(Working outside.)
    I read through a lot of archived threads and couldn't find any dealing with the intermittent part of my problem, before going permanently out.
    I have the FSM and the diagnostic chart, but will be found dead in a snowdrift with it clutched in my hands before I get it figured out outside.
    Anyone have an idea what would have caused the symptoms I described? Any thermal overload type part that finally would die?
    I have a used untested ECC programmer that I pulled last year, and I put that in and was still black. I had installed it before in summer before replacing the power module with another one I pulled. When it worked, or seemed to, I pulled the programmer and replaced the original one and all was fine for a while.
    larryinalabama is offline Cadillac Owners Connoisseur
    Automobile(s): 1990 Brougham, 1990 Brougham d'elgance 1979 Coupe
    Dec 2013
    1,057
    Re: 87 Brougham ECC gone black. after a couple weeks of intermittent working.
    talismandave likes this.
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,395
    My guess is an intermittent grounding issue
    sven914's Avatar
    sven914 is offline Cadillac Owners Connoisseur
    Automobile(s): 1989 Brougham d'Elegance, 1985 Fleetwood Brougham *Coupe*
    Dec 2008
    4,256
    Quote Originally Posted by larryinalabama View Post
    That saved me a lot of time... Thank you for finding that old thread.
    Mar 2012
    Madison WI
    57
    7,893
    Yes, thank you both, that is so much clearer than the FSM!
    -4 degrees right now, if it warms up a bit I will try today, otherwise, I will be making my way to Chicago in a Honda van.
    larryinalabama likes this.
    Dec 2013
    1,057
    Quote Originally Posted by talismandave View Post
    Hope you get her fixed.
  9. Remove Advertisements
