Olds 307 Distributor shaft oil seal
Results 1 to 4 of 4
1985-1996 Fleetwood and Brougham Forum Discussion, Olds 307 Distributor shaft oil seal in Past Cadillac Vehicle Discussion; Hello! I have a 89 Brougham with an olds 307 that burn a bit of oil, i noticed this comment ...
    Jeppi94's Avatar
    Jeppi94 is offline Cadillac Owners Fanatic
    Automobile(s): 1989 Cadllac Brougham
    Jul 2013
    Gothenburg, Sweden
    22
    158
    Hello!
    I have a 89 Brougham with an olds 307 that burn a bit of oil, i noticed this comment on "The Brougham Society on facebook"
    "There was an issue in these that caused them to use oil. From what I remember it had something to do with a seal on or around the distributor shaft. Caused major oil burning, tho. Otherwise a good motor."
    Anyone on here that can confirm this, because i can't find it anywhere myself.
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,395
    I've never heard of that....and I missed that post on TBS
    deVille33 is offline Cadillac Owners Connoisseur
    Automobile(s): 1977 Coupe (blue), 1977 Coupe (yellow), 1977 Coupe (green)
    Mar 2006
    Western Massachusetts
    1,493
    Re: Olds 307 Distributor shaft oil seal
    The early Olds engines had an "O" ring seal. Don't remember what the 307's had and I am not sure what effect they had on the oiling system.
  5. #4
    Feb 2003
    california
    69
    6,608
    An oil leak thru the shaft of the distributor would pump oil up onto the module plate. It would not affect oil consumption.
  6. Remove Advertisements
