94 FWB coolant leaking on water pump - Page 2
Results 16 to 30 of 39
1985-1996 Fleetwood and Brougham Forum Discussion, 94 FWB coolant leaking on water pump in Past Cadillac Vehicle Discussion; Originally Posted by cadillacmike68 Don't forget the GM pellets. Had you not said this, I would have forgotten the GM ...
  1. #16
    netfreak is offline Cadillac Owners Member
    Automobile(s): 1994 Fleetwood Brougham
    Aug 2013
    BC, Canada
    33
    26
    Re: 94 FWB coolant leaking on water pump
    Quote Originally Posted by cadillacmike68 View Post
    Had you not said this, I would have forgotten the GM pellets. Never heard of these before today. Just gotta figure out where to get them...
  2. #17
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,894
    Do not use pellets in an lt1 car.
  3. #18
    Cadillacboy's Avatar
    Cadillacboy is offline Cadillac Owners Connoisseur
    Automobile(s): 1996 Cadillac Fleetwood Brougham
    Dec 2003
    36
    4,388
    We have not been usin' 'em on our Fleetwood , glad to hear that lol
    However, 96 came with Dex cool coolant as well as pellet to my memory
  5. #19
    Sep 2006
    Ontario, Canada
    44
    7,894
    Dex+pellets=clogged heater core
  6. #20
    Aug 2013
    BC, Canada
    33
    26
    Quote Originally Posted by jayoldschool View Post
    Ahh, so no pellets then?
    I just got the old pump off and gotta get some gasket glue then install the new one. Ended up being a lot more stuff in the way than I thought. I might end up deleting the A.I.R thing if I can.
  7. #21
    Sep 2006
    Ontario, Canada
    44
    7,894
    No pellets.
    Yes, the job is much easier with the air pump gone! You can get plugs for the manifolds at Home Depot. Don't even try removing that front tube in one piece, just cut it in half below the balancer. NOTE: removing the air pump is technically not legal on the 1994. It is legal on the 1995 and 1996, and you need an updated TSB sticker to go on the core support. If you live in an area with strict visual inspection, do not remove it.
  8. #22
    cadillacmike68's Avatar
    cadillacmike68 is offline Cadillac Owners Connoisseur
    Automobile(s): 68 DVC, 96 FLTWD Brg, 09 STS N* Platinum, 11 CTS Premium
    Jan 2005
    Left the desert - Back in FL
    55
    1,272
    ExclamationRe: 94 FWB coolant leaking on water pump
    Quote Originally Posted by Cadillacboy View Post
    Page 6B-8 of the 1996 Service Manual (book 2) states: Important. When refilling the cooling system add two engine coolant supplement sealant pellets GM PN 3634621 or equivalent and coolant antifreeze meeting GM Specification 6277-M.
    Only 2, not 6 as for the NorthStars or 4100s.
  9. #23
    Sep 2006
    Ontario, Canada
    44
    7,894
    I'm well aware of what it says. I'm just giving advice on twenty years of owning multiple LT1s (and most long time LT1 guys will tell you the same thing). GM was unaware of the effects of the tabs/Dex combo when the FSM was written. As always, people can do whatever they like. However, if you add tabs, I will say that I hope you like flushing heater cores
  10. #24
    Aug 2013
    BC, Canada
    33
    26
    I see Dexcool is not green, though when I drained the system it looked like your standard coolant. I'm also not seeing anything in the bay mentioning to only use Dexcool. With this in mind, should I drop 2 of the pellets in when I refill?
  11. #25
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    DEX-COOL didn't exist in '94. Your car was filled with "regular" coolant at the factory.
    ...And FWIW, there is no reason ANY car "requires" DEX. There is nothing special about the aluminum, steel, rubber, and plastic in '96+ GM engines and cooling systems that makes DEX necessary. DEX was designed to be a long life (5 year/100K mile) coolant. And in '96, it was. But most green coolants have been rated for that for over a decade now. There is almost no difference between DEX and standard coolant anyway, other than color and the fact that DEX is scold ate free.
    Also FWIW, GM no longer recommends or uses the pellets. As Jay said, they're known to clog heater cores and other small coolant passages. If for some reason you do decide to use them, they go into a hose, not the surge tank.
  12. #26
    Aug 2013
    BC, Canada
    33
    26
    Thanks. I'll hold off on the pellets but I'll keep them on hand in case anything starts leaking. Got the pump installed yesterday but I won't be finishing the rest of the hoses and coolant fill until next week. Hopefully everything works out.
  13. #27
    HUF's Avatar
    HUF
    HUF is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 FWB 100,*** miles CURRENT. 1991 Seville 175,000 SOLD
    Dec 2005
    MA
    58
    2,109
    By the way, adding Bar Leaks Tabs or powder makes the engine run a few degrees hotter. This is from my experience. Did it two times and got the same result to my surprise.
  14. #28
    Sep 2010
    East Boston MA.
    29
    26,325
    Quote Originally Posted by netfreak
    If something starts leaking, why not just fix it correctly?
  15. #29
    Aug 2013
    BC, Canada
    33
    26
    It's a backup plan. I don't mind throwing parts at problems but I really never want to remove another LT1 water pump...
  16. #30
    Sep 2006
    Ontario, Canada
    44
    7,894
    If you do the work correctly, nothing will leak. Don't worry.
  17. Remove Advertisements
