81cdv shut engine light comes on
Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By sven914
1985-1996 Fleetwood and Brougham Forum Discussion, 81cdv shut engine light comes on in Past Cadillac Vehicle Discussion; So my buddy picks up an 81 cdv project. I believe it has the 368 engine. He claims that when ...
    cadillaccruiser703 is offline Cadillac Owners Member
    Automobile(s): 1954 coupe deville, 1984 fleetwood 2dr
    Jul 2013
    28
    So my buddy picks up an 81 cdv project. I believe it has the 368 engine. He claims that when he starts it a temp light comea on. Then the shut engine light comea on and the whole car shuts off. My question is what causes this and how to repair it. Or even by pass it. Ive never come across this issuse since most vehicles have gauages.
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,397
    I'd guess the coolant temp sensor is bad.
    1980coupe's Avatar
    1980coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 78 CDV, 79 CDV delegance, 80 CDV, 80 FWB 2dr delegance (rip)
    Jan 2009
    El Paso, TX
    40
    1,150
    Re: 81cdv shut engine light comes on
    Even if it were the coolant sensor it wouldn't shut off the car..but then again this engine, though similar to mine in my 80 coupe, has more electrical stuff.
    sven914's Avatar
    sven914 is offline Cadillac Owners Connoisseur
    Automobile(s): 1989 Brougham d'Elegance, 1985 Fleetwood Brougham *Coupe*
    Dec 2008
    4,256
    Please get a verification as to what the lights exactly say.
    I do not believe there is a "shut engine light," but I know there are two lights that say "Stop Engine Temp" and "Stop Engine Oil Pressure."
    Neither of these lights have the capability of turning off the engine; the car's computer is not smart enough to kill the engine when there is no coolant or oil, and it will happily allow the engine to destroy itself before doing anything to intervene. However, if the engine doesn't have any oil pressure, there might be too much friction for the pistons to move, thus killing the engine instantly.
    The lights may in fact be inconsequential; both lights illuminate when the ignition is turned to RUN and if I recall correctly, both stay on for a second or two after the engine is running. The engine may be stalling because its not getting enough fuel, air, or spark, and the Stop Engine lights may simply be on because the ignition is in the run position.
    1980coupe likes this.
    Robin Banx's Avatar
    Robin Banx is offline Cadillac Owners Enthusiast
    Automobile(s): 1983 FWB (Mac), 1981 SDV (Junkyard Dog)
    Dec 2007
    Vancouver, B.C. Canada
    729
    ^^My '81 368 CID engine does not have a "stop engine" light. It has a single "check engine" light that come on when the ignition switch is turned on. When the car starts, if there are no trouble codes set by the computer the light will go out. If there is one or more trouble codes set (this can be determined by entering diagnostic mode and checking it) then the "check engine" light will stay on until the trouble codes are addressed or repaired and the codes are cleared from the computer. A shop manual for the 81 car would be a very good idea.
    Cheers.............R.
    ^^ I feel as if I am wearing orthopedic shoes. I stand corrected. My "81 car does have a "stop engine/oil pressure" light which lights when the key is turned on prior to start up. It then goes out when the oil pressure is sufficient after start up. I had to physically check my own car to make sure. Sorry for the confusion on my part.
    Cheers...........R.
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    8,021
    The oil pressure switch will have a link with the fuel pump. After the start, if the sender does not report pressure, power to the fuel pump is cut. Solution, test/replace oil sender.
    Jul 2013
    28
    Thanks for the info guys. Ill double check what exactly the light says
    sven914's Avatar
    Dec 2008
    4,256
    Quote Originally Posted by jayoldschool View Post
    That sounds way too advanced for '81... But than again, so does variable displacement and on-board diagnostics.
  11. Remove Advertisements
