1987 Brougham D'Elegance: Rumbling noise from under vehicle/ speedometer not working
Results 1 to 4 of 4
1985-1996 Fleetwood and Brougham Forum Discussion, 1987 Brougham D'Elegance: Rumbling noise from under vehicle/ speedometer not working in Past Cadillac Vehicle Discussion; Hi, everyone, just wondering if anyone could offer any help or explanation to why this is happening. There is a ...
    McNeill is offline Cadillac Owners Member
    Automobile(s): 1987 Fleetwood Brougham D'Elegance
    Dec 2013
    28
    3
    Hi, everyone, just wondering if anyone could offer any help or explanation to why this is happening. There is a distinct rumbling coming from under the vehicle when the car is in motion. Also, my speedometer doens't appear to be working. Any And all help is greatly appreciated
    mjs182004's Avatar
    mjs182004 is offline Cadillac Owners Enthusiast
    Automobile(s): 91Broughamd'Elegance,06STS-V,76FWBd'Elegance,98SevilleSTS
    Dec 2008
    Eastlake, Ohio
    30
    769
    I just had this problem with mine. It's the vehicle speed sensor that is on the transmission. kind of an expensive part. But it is really easy to change. Jack up the car and crawl under on the drivers side. You will see a wire harness to the back of the transmission, going to a round sensor about the size of a baseball. there is one 10mm bolt that holds it in there. once you remove the bolt, you kinda have to pry it out (there is a O-Ring to seal it on the sensor). Watch out for transmission fluid, as some will come out. also there will be a plastic gear that will probably fall out. Make sure you put the pointy end towards the transmission. Then it is reverse order to put the sensor back in. Also make sure you get the right one according to your axle gears.
    j2rossit is offline Cadillac Owners Enthusiast
    Automobile(s): 85 FW Brougham, 68 Wildcat 'vert, 92 & 96 Roadmaster Wagons
    Jan 2011
    Southern Ontario
    934
    Re: 1987 Brougham D'Elegance: Rumbling noise from under vehicle/ speedometer not work
    When did they stop using the Speedometer Cable. My 85 is cable driven. Were the Olds 307 powered setups using the tranny mounted speed sensors?
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,397
    Quote Originally Posted by j2rossit View Post
    Yes.
  7. Remove Advertisements
