'94 Fleetwood hesitates when in overdrive
Results 1 to 12 of 12
Like Tree3Likes
  • 1 Post By silverfox103
  • 1 Post By csbuckn
  • 1 Post By Aron9000
1985-1996 Fleetwood and Brougham Forum Discussion, '94 Fleetwood hesitates when in overdrive in Past Cadillac Vehicle Discussion; Hi everyone, Boy, what a week! First, my '94 Fleetwood developped an oil leak at the oil filter adapter. No ...
    Alscad56's Avatar
    Alscad56 is offline Cadillac Owners Fanatic
    Automobile(s): 1956 Sedan Deville,1994 Fleetwood
    Aug 2011
    Les Cedres,QC,Canada
    104
    Hi everyone,
    Boy, what a week! First, my '94 Fleetwood developped an oil leak at the oil filter adapter. No problem, easy fix. Then the "check engine" light went on. And the car started to hesitate after shifting into overdrive. Seems ok when cold. Transmission oil level ok, oil color good.
    To end all this, I got into a fender bender two days ago on the highway. While passing into another lane, the lady in front decided to slam on her brakes (there was enough space in front of her to fit three buses). So I hit the brakes, and uh..oh...brake line split! So my car bumped into hers, she brakes more, I bump again, and again. All this happened so fast, I had no time to think of the emergency brake.
    So after all this, my front bumper pushed in about 1.5 inches on one side. The bumper shock took the impact. I hope I can pull it back out. Then That night, I started a bad cold...
    Anyway, 'nuff ranting, my question is, does anyone have an idea what may cause the car to hesitate on overdrive, while warm?
    Thanks!
    silverfox103's Avatar
    silverfox103 is online now Cadillac Owners Fanatic
    Automobile(s): 96 Fleetwood & 07 CTS, 94 Roadmaster Wgn & 94 Caprice Wgn
    Aug 2012
    Littleton, NH & St. Simons, GA
    68
    446
    Re: '94 Fleetwood hesitates when in overdrive
    As long as the shock is not bent or leaking, you should be able to pull it out. I bought a 96 FWD about a year ago. Someone, before I bought it, kissed the rear bumper. I have a nylon strap that I looked around the bumper shock. On the other end I connected it to my hitch on the wagon. Applied a little gas and out it came.
    Tom
    Alscad56 likes this.
    Automobile(s): 1999 BMW 740 Il. 2005 Jag XK8, 1988 Mercedes Benz 300 SE
    Feb 2003
    california
    69
    6,689
    A hesitation in overdrive is usually an engine miss not felt until the engine and transmission are "locked up" in overdrive. I would look first at the secondary ignition ie plugs and wires for cracked plugs or shorting, old, wires. AND next time assume the guy in front of you is going to suddenly STOP and leave enough room! Hitting someone from the rear is always your fault.
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,619
    We'll give him the benefit of the doubt on rearending someone since his brake line busted. I think its the torque converter thats giving you the problems at cruising speeds.
    Alscad56's Avatar
    Aug 2011
    104
    Quote Originally Posted by csbuckn View Post
    Thank-you! If I had brakes, I would not have hit the car. We always take for granted our cars won't fail on us that when it does, it catches us by surprise...especially on the freeway, with plenty of room between you and the car ahead. I changed lanes. Right at that moment, the car in front slammed on the brakes...for no reason. My time of reaction was one second. By the time I realized my brakes failed, it was too late to do evasive manuevers without causing a major pile-up...so, I bumped the car. Everytime I tried to move onto the shoulder, the car ahead kept slowing down, causing me to bump again until I had enough room to pull over. Trust me...it's hard to stop on time without your brakes!!
    Quote Originally Posted by carnut View Post
    Thanks. I hope it's not the opti-spark failing...could the oxygen sensors have something to do with it? I'm asking because this problem started only after my oil filter adapter sprung a leak, causing oil to splash onto the cat and oxygen sensor. Co-incidence?
    drmenard is online now Cadillac Owners Connoisseur
    Automobile(s): 95 FWB 81SDV 96 FWB 94 Fleetwood
    May 2003
    Massachusetts
    1,208
    With me, your buck, has been plugs, wires or cap... How old are they?
    Feb 2003
    california
    69
    6,689
    Unlikely a cat converter or Oxy. sensor. Oil on the outside has no bearing on how they perform internally. And.............. I will temper my opinion on the collision! A busted brake line is a rare occurence that you could not have forseen. I say again, most likely plugs and/ or wires causing the engine to buck, hesitate in overdrive.
    Alscad56's Avatar
    Aug 2011
    104
    Thanks. Plugs were changed last year. I'll have to check the wires.
    Alscad56's Avatar
    Aug 2011
    104
    My car is still at the garage...this being frozen outside and I have no garage. My mechanic showed me my brake lines...apparently, when I hit the brakes to avoid a collision, my brake lines busted in 3 different places which affected both reservoirs in my master cylinder, which essentially killed my brakes.
    This forces me to remind everyone to not take for granted that everything is fine with your cars. Do a check-up! Don't be foolish like I was.
    Why do my cars always break down in the worst weather conditions?
    Alscad56's Avatar
    Aug 2011
    104
    Update...
    My car had the brakes fixed and the oil filter adapter also fixed. Strangely enough...the "Hesitation" on overdrive has stopped!
    The Cadillac is driving great...like it should!
    So, the hesitation started when the oil filter sprung a leak, and ceased when the leak was fixed...go figure..that's quite a co-incidence!
    Aug 2012
    68
    446
    PM sent
    Aron9000's Avatar
    Aron9000 is offline Cadillac Owners Master
    Automobile(s): Past: 95 Fleetwood, 91 Brougham. Now: 92 Lexus SC300
    Jul 2008
    Nashville, TN
    5,418
    Man your story makes me glad to live in the south, with no snow, and NO SALT. Even our $500, 20 year old Toyota trucks have ZERO rust around here. Quite frankly if you take care of your old car and its a quality piece out of the factory to start with, cars tend to age as well as humans down south lol.
  15. Remove Advertisements
