Signs of a transmission going dead - Page 2
Results 16 to 30 of 31
1985-1996 Fleetwood and Brougham Forum Discussion, Signs of a transmission going dead in Past Cadillac Vehicle Discussion; manual didnt come with the car when i bought it,so you saying i cant change filters? i dont know much ...
  1. #16
    85 FLEETWOOD COUPE's Avatar
    85 FLEETWOOD COUPE is offline Cadillac Owners Fanatic
    Automobile(s): 96 CADILLAC FLEETWOOD BROUGHAM
    May 2011
    GEORGIA
    463
    Re: Signs of a transmission going dead
    manual didnt come with the car when i bought it,so you saying i cant change filters? i dont know much about transmissions so its not like a filter for a motor?
  2. #17
    silverfox103's Avatar
    silverfox103 is offline Cadillac Owners Fanatic
    Automobile(s): 96 Fleetwood & 07 CTS, 94 Roadmaster Wgn & 94 Caprice Wgn
    Aug 2012
    Littleton, NH & St. Simons, GA
    67
    387
    Not sure what he's talking about, but filters are made to be replaced. They do a job and when they can't do that job anymore, you need to replace the filter. You can buy them at any auto supply. In fact whenever there is a sign of a tranny problem, the first thing to do is change the fluid and filter.
    Tom C.
  3. #18
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,605
    What ape is saying is that if a tranny breaks down so much that it actually clogs a filter and causes problems, it's probably too late to do a filter/fluid change. But the only thing you can really do short of taking it in is change the fluid/filter. Really easy but messy.
  4. #19
    May 2011
    GEORGIA
    463
    im going to try to change the filter and oil and see what happens ,so is this what i need for my 96? http://www.autozone.com/autozone/par..._722781_0_8069
  5. #20
    Jan 2008
    Minneapolis
    5,605
    Yep.
  6. #21
    May 2011
    GEORGIA
    463
    and Dexron II
  7. #22
    MrHolland's Avatar
    MrHolland is offline Super Moderator
    Automobile(s): 2010 Platinum Escalade, 1996 Fleetwood Brougham
    Jul 2010
    Midwest
    5,617
    The last transmission I destroyed actually chuckled and whispered that'll be a $1000.....
  8. #23
    j2rossit is offline Cadillac Owners Enthusiast
    Automobile(s): 85 FW Brougham, 68 Wildcat 'vert, 92 & 96 Roadmaster Wagons
    Jan 2011
    Southern Ontario
    934
    Quote Originally Posted by 85 FLEETWOOD COUPE View Post
    really interesting,im going to try this out on my day off this weekend thanks for the words,ill report back to give update on this part
    I LOOKED AT IT AND # 20 IS THE CLOSEST TO MY SITUATION HERS WHAT IT SAID-20. Trans seems noisy when moving in 1st and Reverse, noise goes away instantly if you shift to N or the trans goes into 3rd gear: Reaction planetary is worn out due to high miles or insufficient lubrication. Not a critical failure, but not a good sign either. R&R sooner rather than later.
    whats the Reaction planetary?
    Automatic transmissions have planetary gear sets. There is a gear in the middle (sun gear), gears meshed with the sun gear that travel around the sun gear (planets) and a ring gear that surrounds all the planets and holds them against the sun. All the planets are connected to an armature. By locking different items (sun, planet armature, ring) you can make different gear ratios. The Reaction planetary I believe is what locks the planet armature.
  9. #24
    May 2011
    GEORGIA
    463
    So basically i got to get ready to change transmissions?
  10. #25
    Aug 2012
    67
    387
    You can never have too many tranny's. I used to have three spares, down to two now. When they go, it usually is a surprise. Mine happened 700 miles from home, be prepared. On that trip, it was my Carpice wagon, I carried every part imaginable, except the transmission. And you know the rest of the story, flat bedded home. Changing the fluid and filter, is an act of desperation, seldom changes anything.
    Good Luck
    Tom C.
  11. #26
    Jan 2011
    Southern Ontario
    934
    My guess is that as it gets worse, the tranny will start slipping in the gears where the armature is supposed to be locked. You'll have to call a tranny shop to find out if it can be repaired reasonably or if a replacement is in order.
  12. #27
    May 2011
    GEORGIA
    463
    Wow thats what not i wanted to hear lol so changing filter and fluids is out the window i guess
  13. #28
    Jan 2011
    Southern Ontario
    934
    I'm just going off of your diagnostic #20. It makes sense that the sound would only be in certain gears since the armature is not being locked in all gear ratios. I don't know if new fluid would help it engage or not.
  14. #29
    May 2011
    GEORGIA
    463
    rite rite understood dang got me here thinking to sell the car now
  15. #30
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    If the car still moves ok change the fluid and filter. If the car is missing a gear or won't go then it's too late.
  16. Remove Advertisements
