Power door locks-89 Brougham
Results 1 to 5 of 5
1985-1996 Fleetwood and Brougham Forum Discussion, Power door locks-89 Brougham in Past Cadillac Vehicle Discussion; Hello - the power door locks on my 89 Brougham do not work. I was given 2 new locks but ...
    Oliver119 is offline Cadillac Owners Member
    Automobile(s): 1983 Sedan De Ville 89 Brrougham
    Mar 2013
    BUFFALO NY
    65
    12
    Hello - the power door locks on my 89 Brougham do not work. I was given 2 new locks but the mechanic said they were 3 prong switches and I need 5 prong switches. Is this correct? I can't seem to find any online> Any help would be appreciated. Did GM make a "standard" switch around that time in one of their other lines I might be able to use? Thanks
    1980coupe's Avatar
    1980coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 78 CDV, 79 CDV delegance, 80 CDV, 80 FWB 2dr delegance (rip)
    Jan 2009
    El Paso, TX
    40
    1,150
    Re: Power door locks-89 Brougham
    Have you checked the fuse?
    I know that some switches from later models are different and wouldn't work on mine. Have you tried eBay?
    Mar 2013
    BUFFALO NY
    65
    12
    I never thought of that. Would one fuse cover both switches? thanks
    1980coupe's Avatar
    Jan 2009
    El Paso, TX
    40
    1,150
    Both switches as to both sides of car?
    Then yes.
    sven914's Avatar
    sven914 is offline Cadillac Owners Connoisseur
    Automobile(s): 1989 Brougham d'Elegance, 1985 Fleetwood Brougham *Coupe*
    Dec 2008
    4,256
    The fuse you want to check is the Body Fuse; it's a 20 amp fuse located in the fuse panel behind the driver's side kick panel. If you want to check the fuse before pulling it, check to see if the cigar lighters or the interior courtesy lights (the square lights on each door) work. If the courtesy lights and cigar lighters work, the body fuse is working and does not need to be replaced.
    If the body fuse does not need to be replaced, then the issue may be with the issue with the Door Lock Relay, which sends power to each of the lock motors. The Door Lock Relay is supplied power through the Horn Circuit Breaker (also located in the under dash fuse block). To check the Circuit Breaker, press the horn button on the steering wheel. If the horn does not go off, the Horn Circuit Breaker has failed and needs to be replaced.
    The Lock Switches are three pronged, so the ones you have are probably correct. The Door Lock Relay is five pronged, so that may have been what your mechanic was thinking of. It is unlikely that both Lock Switches would fail at the same time, but if the Body fuse and Horn Circuit Breaker are both functioning, I would replace the lock switches. You should also have your mechanic verify that both Lock Switches are receiving power and the lock system is properly grounded.
  8. Remove Advertisements
