spark plug wire issue
Results 1 to 6 of 6
1985-1996 Fleetwood and Brougham Forum Discussion, spark plug wire issue in Past Cadillac Vehicle Discussion; anyone have any issues with the driverside spark plug wires. i started having a rough idle recently and after some ...
    CadillacPimpinNOLA is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 Fleetwood 1968 coupe DeVille
    Jul 2009
    Metairie/New Orleans,LA
    32
    1,152
    i started having a rough idle recently and after some headaches remember a problem a while back and sure enough.
    the plug wire on the driver side rear cylinder was burned, its run through the metal shield the exact same way the factory ran them.
    the car has 46k miles now and will be the 3rd set of wires when i get them but just as the last issue, it was the same wire that burned up last time
    HUF's Avatar
    HUF
    HUF is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 FWB 100,*** miles CURRENT. 1991 Seville 175,000 SOLD
    Dec 2005
    MA
    58
    2,112
    Re: spark plug wire issue
    Looks like you are talking about your 1995 Fleetwood. You can replace just that wire. I know it is a headache. Make sure you use proper loom rated for underhood use. It should have a grey stripe running along the loom.
    85 FLEETWOOD COUPE's Avatar
    85 FLEETWOOD COUPE is offline Cadillac Owners Fanatic
    Automobile(s): 96 CADILLAC FLEETWOOD BROUGHAM
    May 2011
    GEORGIA
    463
    Make a custom shield for it maybe???
    Jul 2009
    32
    1,152
    i have to get some kind of heat wrap. its run through the factory metal shield, the factory plug wire burnt and the set i replaced it with burnt, just that 1 wire...nut i did read on impala forumn that the #7 has burnt on other ppl so im not the only one
    part of my problem also was when i changed the coil wire out yesterday, it had a split in the boot, i did notice it arching on the waterpump right before i changed the wires
    Jeff R's Avatar
    Jeff R is offline Cadillac Owners Enthusiast
    Automobile(s): 1970 Coupe De Ville//Cessna 172
    May 2013
    St. Louis
    47
    542
    Put a piece of hose (fat vacuum line for example) on the wire where it goes thru. You can just replace that scrap of hose every year or so as preventative maintenance.
    rodnok01's Avatar
    Feb 2012
    NC
    6,652
    I have put spark plug wire heat shields(they are flexible) on my wires before. They slip on, been a few years since used them Summit carried them or Jets. Not sure they will fit your model through factory shields. Saved a set of 200+ wires for me.
  9. Remove Advertisements
