Page 2 of 2 FirstFirst 12
Results 16 to 24 of 24
Thread: 1979 coupe deville chassis
  1. #16
    deVille33 is offline Cadillac Owners Connoisseur
    Automobile(s): 1977 Coupe (blue), 1977 Coupe (yellow), 1977 Coupe (green)
    Mar 2006
    Western Massachusetts
    1,493
    Re: 1979 coupe deville chassis
    The closest truck frame would be from a 1/2 Chevy or GMC 1/2 ton short bed step-side, fleetside, fender side or wideside pickup. They were 4" shorter in wheel base, so you would have to reset the body. The specs I have were from 1985 - 1989. They may have had a longer production run, up to the 90's when GM changed the truck platforms due to the false allegations of gas tank explosions.
  2. #17
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,985
    Have you actually seen a truck frame swap done? I don't understand how it would work. Cars have a perimeter frame, the body drops down and the frame tucks up in the rockers. The truck frame is a ladder frame, the car body would be sitting up in the air, resting on the floorpans. The rear frame doesn't have the kickup for the axle like a car, it is much flatter to accommodate the bed. The front A arms are located lower on the frame than the car.
  3. #18
    Jeff R's Avatar
    Jeff R is offline Cadillac Owners Enthusiast
    Automobile(s): 1970 Coupe De Ville//Cessna 172
    May 2013
    St. Louis
    47
    546
    My grandparents had a 77 in CT. Winters were not good on these cars up there and the frame rusted thru. From what I understand it was at a shop on a lift and the poor old thing started to bend/sag. I didn't see it but from what I understand my grandmother had to drive it to the dealership to trade it in with a rope/cable from the back bumper,up over the roof to the front bumper. Needless to say she got the "Rough" trade in value!!
    Jeff
  4. #19
    Mar 2006
    1,493
    Yes, I have seen these mods. Done around here for off road crazies, was a major rage in my area for a long time. The 1/2 tons have a frame that is closer to the basic characteristics of the autos. They do not raise as high as the 3/4 ton frames. I believe the control arms will interchange which will help lower the stance and you can do what you will with he rear. He is going to have to make alterations if he uses a stock frame. Someone else has a thread in here regarding these issues also.
  5. #20
    Sep 2006
    Ontario, Canada
    44
    7,985
    Ok, I understand what you mean. Car bodies on truck frames for 4x4s have been done many times. However, this guy wants a lowrider. A truck frame won't work for that (with a car body).
  6. #21
    Mar 2006
    1,493
    Agreed, the pic displays a 4 WD setup. Notice that frame is longer WB than the Cadillac frame was. The truck frames I'm suggesting are 2 WD with a coil over rear suspension. The frames were beefier along the side rails because they did not rely on the body to reinforce the span between the front and rear sections.
  7. #22
    Sep 2006
    Ontario, Canada
    44
    7,985
    I've got a coil rear spring RWD truck. That frame is not going under a Cadillac. Too narrow.
    I'm not actually sure the truck frame would be stronger, as well. It's open C channel all the way back.
  8. #23
    Mar 2006
    1,493
    That is the old style ladder frame. The frames used on the late 70's - 80's were different.
  9. #24
    Sep 2006
    Ontario, Canada
    44
    7,985
    When I see one under a lowrider Cadillac, I'll believe it.
  • You may not post replies
