Aluminum intake on a 1979 SDV 425CID
Results 1 to 4 of 4
1985-1996 Fleetwood and Brougham Forum Discussion, Aluminum intake on a 1979 SDV 425CID in Past Cadillac Vehicle Discussion; Hello, just wondeing if anyone has installed an aluminum intake (Edelbrock Performer) on a 425. It is listed as available ...
    cookieeater is offline Cadillac Owners Member
    Automobile(s): 79 DeVille (Sedan), 96 DeVille, 05 DeVille
    Nov 2004
    Orlando,FL
    63
    63
    Hello,
    just wondeing if anyone has installed an aluminum intake (Edelbrock Performer) on a 425. It is listed as available for the 472 and 500 and not the 425. I know the 425 is very very similar. I m thinking it will work. Thanks in advance, Kim
    deVille33 is offline Cadillac Owners Connoisseur
    Automobile(s): 1977 Coupe (blue), 1977 Coupe (yellow), 1977 Coupe (green)
    Mar 2006
    Western Massachusetts
    1,493
    Re: Aluminum intake on a 1979 SDV 425CID
    You will have to check the deck height of the 425 against that of the other 2 engines. I am sure the deck height of the 425 and the 368 is the same as the 472. The difference in the two is that the 425 was a single plane manifold to accommodate the emissions system used in 1977 - 79. The 472 was a dual plane type manifold and will interchange with the '77 - '79 manifold.
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    It should fit. I've used 500 C.I. intakes on 425s and 425 on 500s.
    It will not work well with a 368 due to port sizes.
    afaia1978's Avatar
    afaia1978 is online now Cadillac Owners Member
    Automobile(s): 1979 Coupe Deville
    Apr 2009
    Placentia, Ca.
    73
    I have seen other people use them on the 425's and they fit just fine. The only problem I can think of is that the Edelbrock is a Non-Egr manifold which might lead to a problem if you plan on reinstalling all the smog equipment.
  7. Remove Advertisements
