1969 coupe deville Rear End Swap?? bc one legged burnouts = :(
Results 1 to 3 of 3
1985-1996 Fleetwood and Brougham Forum Discussion, 1969 coupe deville Rear End Swap?? bc one legged burnouts = :( in Past Cadillac Vehicle Discussion; hello everyone, i have a 1969 cadillac coupe deville (472 th400) and the rear end knocks occasionally. i found a ...
    gsautotech's Avatar
    gsautotech is offline Cadillac Owners Member
    Automobile(s): 1968 fleetwood brougham, 1969 coupe deville
    Jun 2009
    10
    hello everyone, i have a 1969 cadillac coupe deville (472 th400) and the rear end knocks occasionally. i found a 8.8 ford mustang rear end, would this work? am not worried about the suspension springs not lining up, i just need a replacement rear with posi. i searched google and found some people have used a 9" ford reared but have not mentioned which ford it was removed from. what do you guys recommend? btw i also have a 1968 fleetwood brougham
    sedan, is it wise to swap the carriers with the 69 deville?
    deVille33 is offline Cadillac Owners Connoisseur
    Automobile(s): 1977 Coupe (blue), 1977 Coupe (yellow), 1977 Coupe (green)
    Mar 2006
    Western Massachusetts
    1,493
    Re: 1969 coupe deville Rear End Swap?? bc one legged burnouts = :(
    Knocking? Could be your paxal joint going away. I am sure you could change out the '68 for the '69 with no problems.
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,894
    The Mustang 8.8 will not be wide enough, and probably not strong enough.
