Steering wheel not centered
Results 1 to 6 of 6
1985-1996 Fleetwood and Brougham Forum Discussion, Steering wheel not centered in Past Cadillac Vehicle Discussion; The steering wheel on my 68 is off center by about 90 degrees. The side of it is blocking the ...
    sams2100 is offline Cadillac Owners Fanatic
    Automobile(s): 1968 DeVille Conv, 1999 DeVille, 2003 Escalade
    Oct 2008
    125
    The steering wheel on my 68 is off center by about 90 degrees. The side of it is blocking the view of the speedometer when driving straight down the road. Also the turn signals seem to click off too soon which may be due to the wheel not being centered, but not sure.
    Is it easy to adjust this?
    drmenard is offline Cadillac Owners Connoisseur
    Automobile(s): 95 fleetwood 81 deville
    May 2003
    Massachusetts
    1,181
    Re: Steering wheel not centered
    When the front end is lined up they should make sure that it is centered.. But if your not going to get it lined up because all the parts are tight , what I have done is just pull off the steering wheel and put it back straight.. Should not be too hard on a 68.
    j2rossit is offline Cadillac Owners Enthusiast
    Automobile(s): 85 FW Brougham, 68 Wildcat 'vert, 92 & 96 Roadmaster Wagons
    Jan 2011
    Southern Ontario
    934
    Pulling the steering wheel and re-installing it on a different spline can get you close, but your turn signals will still not cancel properly.
    You'll need to get an alignment done to get it centered so that the signals cancel properly.
    The Ape Man's Avatar
    The Ape Man is offline Cadillac Owners Connoisseur
    Automobile(s): '80 Fleetwood Coupe, 1994 and 1995 Mercedes 140 Coupe
    Feb 2005
    Southern NJ
    54
    2,096
    Depends WHY the wheel is not centered. A normal wheel alignment does not include pulling the steering wheel off.
    If someone had their paws in the column and did not mark the wheel before pulling then all it would need is to be re-clocked.
    Could also mean real problems in the steering/suspension.
    What's the history if these items?
    Oct 2008
    125
    Quote Originally Posted by The Ape Man View Post
    I have no history of it, the previous owners dad owned it and he passed away. It has a date in the shop next week, so will see what they discover with it then I guess.
    Thanks for the insight into the possible problems with it.
    Feb 2005
    Southern NJ
    54
    2,096
    OK. Make sure they know the wheel is off center before they do anything.
    Best of luck.
  9. Remove Advertisements
