Plugs and Wires
Results 1 to 7 of 7
1985-1996 Fleetwood and Brougham Forum Discussion, Plugs and Wires in Past Cadillac Vehicle Discussion; I have been having some problems with the torque converter not locking up, or when it is locking up the ...
    fireman130's Avatar
    fireman130 is offline Cadillac Owners Member
    Automobile(s): 1993 Cadillac Fleetwood Brogham, 73,000 miles
    Oct 2013
    43
    22
    Plugs and Wires
    I have been having some problems with the torque converter not locking up, or when it is locking up the engine is misfiring (we think) I have another post started problems at highway speeds. What kind of plugs and wires are the best for my 1993 Cadillac Fleetwood Brogham with the TBI 5.7 engine. Thank you
    charley95 is offline Cadillac Owners Member
    Automobile(s): 91 brougham
    Sep 2013
    53
    Re: Plugs and Wires
    I use AC Delco. Mis-firing shouldn't have anything to do with the TC.
    Cadillacboy's Avatar
    Cadillacboy is offline Cadillac Owners Connoisseur
    Automobile(s): 1996 Cadillac Fleetwood Brougham
    Dec 2003
    36
    4,390
    Re: Plugs and Wires
    + Fleetwood Brougham
    drmenard is offline Cadillac Owners Connoisseur
    Automobile(s): 95 fleetwood 81 deville
    May 2003
    Massachusetts
    1,187
    Re: Plugs and Wires
    I have had a misfire feel like it was the transmission... I would change the plugs and wires with what was stock in that car... Some parts guys thy to tell you that THESE plus are better, some maybe are, but by sticking with stock your not adding to your problems..
    fireman130's Avatar
    Oct 2013
    43
    22
    Re: Plugs and Wires
    I am going to try the plugs and wires before the transmission solenoid, that will be the easier fix to try first.
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    Re: Plugs and Wires
    MSD makes the best spark plug wires but you have to order them. If you want to get them from the parts store, try to get AC Delco or at least something with lifetime warranty.
    Feb 2003
    california
    69
    6,680
    Re: Plugs and Wires
    A/C Delco!!! When a torque converter locks up there is no slippage or cushion between the engine and transmission so IF there is a bad plug or wire, you will feel it! I've had a cracked insulator on a plug cause a jerkiness once in lockup. Found it while replacing all the plugs.
  10. Remove Advertisements
