92 Brougham starting problem, any advice appreciated
Results 1 to 9 of 9
1985-1996 Fleetwood and Brougham Forum Discussion, 92 Brougham starting problem, any advice appreciated in Past Cadillac Vehicle Discussion; I have a 92 Brougham 5.7L with almost 87k on it. Hd it for a few weeks now and all ...
    wtsn is offline Cadillac Owners Member
    Automobile(s): 92 Eldorado (base)
    Oct 2011
    Houston, TX
    24
    I have a 92 Brougham 5.7L with almost 87k on it. Hd it for a few weeks now and all has been good without problems. Parked it for 5 days and when I went to start it lights, radio and everything turned on but nothing cranked, dead quiet. Took the battery out to test and found it to be good. Shifted it to neutral and back to park but nothing. Towed it to my mechanic who said when it arrived it started right up. They checked all the obvious but couldn't get it to do the same thing. Has anyone else had this happen or may know what caused this? I pick it up tomorrow but would hate to be stranded in similar situation.
    Thank you
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,395
    Re: 92 Brougham starting problem, any advice appreciated
    my guess would be either starter going out or maybe a loose or damaged wire to the starter
    charley95 is offline Cadillac Owners Member
    Automobile(s): 91 brougham
    Sep 2013
    52
    Maybe neutral saftey switch.
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,896
    In order of probability through personal experience:
    1. Battery connections (including at the starter or grounds)
    2. Starter
    3. Fuel pump
    outsider is offline Cadillac Owners Connoisseur
    Automobile(s): 87 Brougham, 1969 Calais, 95 FWB, 05 CTS, 07 SRX
    Sep 2009
    Buxton, Maine, United
    33
    4,149
    I would agree with 1 and 2 on Jay's list.
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,431
    I'd guess cable or starter. Usually when it's the starter you'll hear a loud click from it sort of like what you hear when the battery is too low to turn it over and you can notice the lights dim.
    drmenard is offline Cadillac Owners Connoisseur
    Automobile(s): 95 fleetwood 81 deville
    May 2003
    Massachusetts
    1,176
    If it don't start again , just give the starter a rap with a wrench or something hard and heavy and if its the starter it will start right up when you try starting it..
    Oct 2011
    Houston, TX
    24
    Thanks guys, I hope it was a one time thing but if it happens again I will start with banging on the starter.
    Sep 2013
    52
    You can also take starter off and have it tested at most auto parts stores for no charge. I had one that was 3 yrs. old that went bad.
  12. Remove Advertisements
