Problem at highway speeds - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 28 of 28
Like Tree2Likes
1985-1996 Fleetwood and Brougham Forum Discussion, Problem at highway speeds in Past Cadillac Vehicle Discussion; Thanks, I think I may tackle it this weekend. This site is awesome I would have never figured this out....
  1. #16
    fireman130's Avatar
    fireman130 is offline Cadillac Owners Member
    Automobile(s): 1993 Cadillac Fleetwood Brogham, 73,000 miles
    Oct 2013
    43
    22
  2. #17
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,880
    Re: Problem at highway speeds
    Fuses first!
  3. #18
    sven914's Avatar
    sven914 is offline Cadillac Owners Connoisseur
    Automobile(s): 1989 Brougham d'Elegance, 1985 Fleetwood Brougham *Coupe*
    Dec 2008
    4,256
    I was wrong about the MAF sensor, however the LO5 does have a Manifold Absolute Pressure (MAP) sensor, which serves the same basic function as a MAF; both sensors are used by the vehicle's computer to measure incoming air and determine the correct air/fuel ratio. A malfunctioning MAP would present the same symptoms as a malfunctioning MAF.
    I have driven more than one vehicle with a disconnected Torque Convert Clutch solenoid, and the TCC solenoid in my own car used to get stuck in the engaged position. Neither case presented anywhere near to the same drivability concerns as stated in the first post. I'm not saying that it's impossible for the TCC solenoid to be causing the issue, I'm just saying that it is highly unlikely.
  4. #19
    fireman130's Avatar
    Oct 2013
    43
    22
    Can I try unplugging the solenoid to see if that helps? I also replaced the MAP sensor in my long list of parts we were throwing at the car. Thanks for the help
  5. #20
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    I'm with Sven. I can't see this as a TC lockup issue but the fix looks pretty cheap and easy and the OP doesn't know if the trans was ever serviced. It would be a good time to service the trans before something bad happens to it anyway. Change the cheap solenoid and hope for the best. In my experience a bad MAP acts blubbery like the choke is on. A lot of cars run fine until they get locked up in OD. When they buck in OD it is usually ignition misfires or EGR. Then we would ask if you used quality plugs and wires or the cheap stuff and used factory plug gaps. Keep us posted.
  6. #21
    fireman130's Avatar
    Oct 2013
    43
    22
    What has me thinking the TCC, is when I put my foot on the brake just a little to unlock the torque converter it works perfect.?????????...... I did replace the MAP sensor with no luck. The car still gives a lean 44 code though.
  7. #22
    drmenard is online now Cadillac Owners Connoisseur
    Automobile(s): 95 fleetwood 81 deville
    May 2003
    Massachusetts
    1,169
    I think it is not the transmission... I think it is a weak coil... I would change the coil and see if it makes a change...
  8. #23
    fireman130's Avatar
    Oct 2013
    43
    22
    I did change the coil with no help. I am going to try plugs and wires they look OK but I have no idea how old they are.
  9. #24
    Feb 2003
    california
    69
    6,611
    I think the lean code is your biggest clue. Once TCC engages and the car is running too lean, it will buck. Have you confirmed fuel pressure at that speed? I think you have a weak fuel pump or the screen (filter, sock) on the float sender.
  10. #25
    fireman130's Avatar
    Oct 2013
    43
    22
    I just took the car up on the interstate and ran the wheels off of it. Around 55 it bucks and carries on, get past that and it ran perfect. I ran about 50 miles with the cruise set at 75 with no problems, get between 50-55 it bucks and surges. If I floor it, it takes off like a rocket.
    This trip I did not get the lean code 44.
  11. #26
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,604
    Well that won't be able to tell us any more info then we have already. The two main focuses are ignition strain or tc lockup. Unfortunately, both will give the same symptoms at cruising speeds at the lowest rpm and highest gear. Maybe take it to a tranny shop and see if they know how to test it? My money is still on tc solenoid.
  12. #27
    fireman130's Avatar
    Oct 2013
    43
    22
    After all that fuss, we ruled out fuel pump, transmission, and spark. It ended up being the fuel pressure regulator on top of the throttle body. It's finally running like a Cadillac again!!!!!!! Thank you everybody for your help.
    csbuckn and talismandave like this.
  13. #28
    Sep 2006
    Ontario, Canada
    44
    7,880
    Great news, and thank you for updating!
  14. Remove Advertisements
