94 fleetwood power antenna problem
Results 1 to 5 of 5
1985-1996 Fleetwood and Brougham Forum Discussion, 94 fleetwood power antenna problem in Past Cadillac Vehicle Discussion; I got this problem that my power antenna wont go up or down, actually its stock in middle position, and ...
    Fleetwoodboule's Avatar
    Fleetwoodboule is offline Cadillac Owners Member
    Automobile(s): 1994 fleetwood brougham
    Jun 2013
    Montreal Canada
    29
    18
    I got this problem that my power antenna wont go up or down, actually its stock in middle position, and when I turn off the car I hear the antenna motor humming, still trying to get it down, and it doesnt stop. I didnt have any problems yet with my battery draining out, even if the car sits for two or three days, but what I wanna know is if there is a fuse I can unplug until I fix it or is it a closed circuit like the power windows, in that case how do I get it to stop ??
    Thanks in advance
    CadillacPimpinNOLA is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 Fleetwood 1968 coupe DeVille
    Jul 2009
    Metairie/New Orleans,LA
    32
    1,152
    Re: 94 fleetwood power antenna problem
    it will stop after a short time, you can unplug it right off the motor in the trunk, the nylon cable inside is broken, it comes with a new antenna mast, if your lucky you can find a replacement on ebay for about $25, if not you can replace the whole motor assembly
    Jun 2013
    Montreal Canada
    29
    18
    alright thanks
  5. #4
    68
    81,723
    There is a tutorial in the Tech Tips forum on replacing the cable. Dealers "should" have the repair kit, but I was unable to find one when I needed it. Got mine from www.antennamastsrus.com.
  6. #5
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,875
    And, yes, there is a fuse for it. Take the fuse out until you fix the antenna. Or, unplug the antenna.
  7. Remove Advertisements
