Transporting a 68 Deville - trailer size?
Results 1 to 12 of 12
Like Tree3Likes
  • 2 Post By jayoldschool
  • 1 Post By turbojimmy
1985-1996 Fleetwood and Brougham Forum Discussion, Transporting a 68 Deville - trailer size? in Past Cadillac Vehicle Discussion; So I bought a 68 Deville convertible remotely and need to transport it about 300 miles. I got some quotes ...
    sams2100 is offline Cadillac Owners Fanatic
    Automobile(s): 1968 DeVille Conv, 1999 DeVille, 2003 Escalade
    Oct 2008
    125
    So I bought a 68 Deville convertible remotely and need to transport it about 300 miles. I got some quotes from transport companies, but with the cost of that, I could rent a trailer and tow it myself with my truck and save a good bit of money. (Car has two busted tires, so cannot be driven long distance)
    These are very wide cars (about 80 inches) so I'm having trouble finding a trailer that sounds like it would work. UHaul has a trailer that they say can handle a 75" outer wheel to outer wheel width, but I have a feeling that isn't large enough.
    Has anyone rented this 75" wide trailer from UHaul to transport a car this wide, or does anyone know if it would work?
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    Re: Transporting a 68 Deville - trailer size?
    I have used them (Uhaul trailers) to haul full size Chevy trucks and it is close in length and width. I think the caddy will fit tightly but you may have to get in and out through the window.
    turbojimmy's Avatar
    turbojimmy is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 Fleetwood 60" Stretch; '07 Avalanche, '95 Nighthawk
    Apr 2004
    New Jersey
    3,963
    I've used the U-Haul trailer to transport Roadmaster wagons and they're 78.1" wide. The LH fender flips down and you can easily get in and out.
    I'd be more worried about length.
    silverfox103's Avatar
    silverfox103 is online now Cadillac Owners Fanatic
    Automobile(s): 96 Fleetwood & 07 CTS, 94 Roadmaster Wgn & 94 Caprice Wgn
    Aug 2012
    Littleton, NH & St. Simons, GA
    67
    398
    Like Turbo said, they will tow Roadmaster Wagons and they are wide and big. Whatever you do, don't let on to Uhaul that you are towing a big car or they'll say the trailer is too small.
    Tom
    turbojimmy's Avatar
    Apr 2004
    New Jersey
    3,963
    You can model tow vehicle and towed vehicle combinations on the U-Haul site. Pick one that works :-p
    My Avalanche towing the Roadmaster wagon was an acceptable combination. However, towing my '01 DTS with an F150 4x4 was not an acceptable combination (I changed the towed vehicle to a Cimmaron and it worked).
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,896
    Why not just change the tires and drive it?
    77CDV and csbuckn like this.
    Oct 2008
    125
    Quote Originally Posted by jayoldschool View Post
    I would if I had rims and tires ready to go, but I don't want to get tires for the 13" rims that it currently has.
    turbojimmy's Avatar
    Apr 2004
    New Jersey
    3,963
    Quote Originally Posted by sams2100 View Post
    You can probably get a pair of rims and tires from a u-pull-it yard for less than the cost of renting the trailer.
    77CDV likes this.
    outsider is offline Cadillac Owners Connoisseur
    Automobile(s): 87 Brougham, 1969 Calais, 95 FWB, 05 CTS, 07 SRX
    Sep 2009
    Buxton, Maine, United
    33
    4,149
    I've hauled my 69 on a 16 or 17 foot 2 axel trailer...had to take the ramps off because it was so big but it can be done.
    I hope those show up.
    turbojimmy's Avatar
    Apr 2004
    New Jersey
    3,963
    The U-haul ramps slide into the bottom of the trailer so you should be good.
    Check the wheelbase of the Caddy versus a Roadmaster wagon. As you can see, there's not much more room there.
    Sep 2006
    Ontario, Canada
    44
    7,896
    Any 5x5 wheel will work. All RWD full size Caddy to 96. 91-96 Caprice/Roadmaster/Custom Cruiser/Fleetwood. All 71-76 GM RWD full size. All 77-90 GM full size wagons. All 5 bolt RWD full size pickups from GM. All 5 bolt GM Astro/Safari vans. Mid 70s full size Fords, too. You probably know someone that will loan you a set of wheels and tires for the trip. I have at least five extra sets in my garage, and there arre lots more like me out there....
    LiQuid Explosion is offline Cadillac Owners Member
    Automobile(s): 1968 Cadillac Deville Convertible
    Jun 2010
    42
    10
    When I graduated flight school in 2002, I rented a 26ish' Penske and a car trailer for my 68 Deville convertible. The plan was to tow the Caddy from Alabama to PA, drive a enterprise rental back to Alabama with a buddy one way hit spring break then drive the Honda Civic I owned back to PA.
    Obviously the fuel efficient Civic was the best option for the long trip.
    Well, I rented the truck and trailer and tried to drive the Caddy on it. I'm here to tell you the Caddy barely fit and the rear wheels we so close to the back. If I remember the car did fit with 20" X 8.5" wheels. It was super awkward and I was really anxious about even getting it on there. One wrong bump and I'm sure it would have been bad.
    So, the plan didn't work and I had to tow the Civic instead. Ended up driving the caddy all the way home.
    I'm here to say if you haven't tried it, don't believe anyone who says it should work. The car is big, long, wide and really heavy. The trailer wheels looked like they were fighting for their lives. Don't even know if the trailer was rated for the 5500lb convertible but, I didn't care much about anything back then but saving some money.
    If you need to get your caddy to maybe a gas station a few miles really slow and your hazards on would probably work but most definitely not a long trip and 55-65mph.
    If anyone has done it or the trailers have gotten better since 2002 speak up. I have tried it personally.
  15. Remove Advertisements
