1968 Deville antenna options
Results 1 to 6 of 6
1985-1996 Fleetwood and Brougham Forum Discussion, 1968 Deville antenna options in Past Cadillac Vehicle Discussion; Hi all. My car has had it power mast removed. Fix antenna now. Is there an option to go back ...
    jukelemon's Avatar
    jukelemon is offline Cadillac Owners Member
    Automobile(s): 1968 Deville Convertible
    Jul 2013
    Louisville, KY
    60
    Hi all.
    Is there an option to go back to a power mast like
    http://www.ebay.com/itm/UNIVERSAL-FI...469466&vxp=mtr
    or another Cadillac, later model type?
    The fixed one is crappy and was not the right one.
    Thanks.
    77CDV's Avatar
    77CDV is offline Cadillac Owners 10000+ Posts
    Automobile(s): 77 CDV, 06 DTS III, 69 FWB
    Mar 2006
    Newbury Park, CA
    45
    10,022
    Re: 1968 Deville antenna options
    Why can't you just install a power antenna where the old one was? Unless the hole was sealed over by body work?
    jukelemon's Avatar
    Jul 2013
    Louisville, KY
    60
    That's my idea.
    My question was/is what kit? I listed one in the post. Would that work?
    I don't want to buy something that someone has already attempted to use. You know?
    Thanks.
    cadillacbart is offline Cadillac Owners Fanatic
    Automobile(s): 1968 DeVille Convertible (current project)
    May 2005
    Thornton, CO
    157
    Almost any will work. There's a ton of space under the fender. Get a fully automatic though so you can wire it to still operate through your factory radio knob, if you still have yours. The hardest part is fabbing a new bracket. I have used plumbing pipe hangers to great success. Easy afternoon project.
    jukelemon's Avatar
    Jul 2013
    Louisville, KY
    60
    Good deal.
    Yeah, my concern is not space but the eschelon (sp?) and rubber piece on the outside.
    That kit has a bunch of different types so I figured it would work.
    But if I can something else from another model/type for cheaper that would be another option too
    Thanks.
    May 2005
    Thornton, CO
    157
    On the two that I have done, using no attachments on the top of the replacement antenna fit right into the eschutcheon tightly and worked out well.
  9. Remove Advertisements
