Headlight Aim 91 Brougham??
Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By csbuckn
1985-1996 Fleetwood and Brougham Forum Discussion, Headlight Aim 91 Brougham?? in Past Cadillac Vehicle Discussion; Unable to find any adjustment screw for headlights? Lights are aiming a little too low and would like to adjust ...
    charley95 is offline Cadillac Owners Member
    Automobile(s): 91 brougham
    Sep 2013
    53
    Unable to find any adjustment screw for headlights? Lights are aiming a little too low and would like to adjust them.
    Wondering if anyone here has done this to their 91-92?
    Thanks
    jayoldschool's Avatar
    jayoldschool is offline GM RWD V8 addict
    Automobile(s): 81 FWB D'Elegance coupe
    Sep 2006
    Ontario, Canada
    44
    7,931
    Re: Headlight Aim 91 Brougham??
    Take the headlight trim off, you should be able to see the adjusters then.
    csbuckn is offline Cadillac Owners Master
    Automobile(s): 84 Coupe w/500
    Jan 2008
    Minneapolis
    5,613
    I believe its on top of the headlight. Open the hood and look for male star screws.
    Sep 2013
    53
    Not finding it. 90-92 had different style headlights and no adjustment screws are anywhere in sight.
    Sep 2006
    Ontario, Canada
    44
    7,931
    Did you take the headlight trim off?
    Jan 2008
    Minneapolis
    5,613
    I have the 90 front clip on mine and just went out and checked. Its under the trim piece under the hood. You have to take that long plastic trim off thats between the radiator support and inside header. I was able to pull it back a little to see one of the adjuster screws. I just did mine a couple weeks ago and stopped in the middle of a side street at night to put them where I wanted.
    mjs182004 likes this.
    Sep 2013
    53
    Quote Originally Posted by csbuckn View Post
    Found it thanks! I was able to adjust with a screwdriver torx bit without having to remove the plastic cover.
    2manyhotrods's Avatar
    2manyhotrods is offline Cadillac Owners Fanatic
    Automobile(s): 1999 Eldorado ETC coupe.
    Jun 2013
    Massachusetts
    438
    I hope in your case they're not rusty and frozen. My 99 Eldorado's adjusters succumbed to the dreaded corrosion disease. The first time I went to aim them they wouldn't budge.
    Trying harder with more leverage on my ratchet and shiny new external star sockets I was greeted with loud snapping noises and the guts came loose, but everything spun loosely.
    I should have soaked the adjusters in penetrating oil first.
    Now I need to buy new headlight assembly's. (Very costly mistake on my part).
    Sep 2013
    53
    That sucks! Sounds like you have luck like mine. Good luck with the fix!
  12. Remove Advertisements
