Ignition/Door lock Replacement. 1968 Deville
Results 1 to 3 of 3
1985-1996 Fleetwood and Brougham Forum Discussion, Ignition/Door lock Replacement. 1968 Deville in Past Cadillac Vehicle Discussion; Hi all. Looking to replace all of these. Can you please recommend a place? I see some on line. Not ...
    jukelemon's Avatar
    jukelemon is offline Cadillac Owners Member
    Automobile(s): 1968 Deville Convertible
    Jul 2013
    Louisville, KY
    60
    Hi all.
    Can you please recommend a place? I see some on line. Not sure of their quality.
    Do I need the Long or Short door lock sets?
    Also, Is it possible to replace the ignition from the bottom as opposed to taking off the Top Dash?
    I took off the Steering Wheel/Lower panel and although tight it seems like you can get it from there.
    Thanks.
    Jason
    jukelemon's Avatar
    Jul 2013
    Louisville, KY
    60
    Re: Ignition/Door lock Replacement. 1968 Deville
    any one?
    cadillacbart is offline Cadillac Owners Fanatic
    Automobile(s): 1968 DeVille Convertible (current project)
    May 2005
    Thornton, CO
    157
    I can't tell you if you need long or short. Mine are fairly short. As for the ignition lock, you can change that from the front of the dash if you have a key for it. Basically you insert the key and the push a pick or large paper clip in the hole on the cylinder, then turn the key counterclockwise and it will come out. I'm sure there are directions online if you google it.
